Old 12-12-2011, 10:03 AM   #1
Robudda723's Avatar
Trader Rating: 24 (100%+)
Default Can any ESC be used with 1s?
I have searched and seen this asked on many threads but can't seem to find a clear cut yes or no answer. I want to be sure before I pick up an ESC.
Can any standard brushless ESC that is not designed for 1s be used with a 1s pack as long as either an external booster or Receiver pack is used?
Thanks,
Rob
Robudda723 is offline   Reply With Quote
Old 12-12-2011, 10:35 AM   #2
jsinclair's Avatar
No not all can
jsinclair is offline   Reply With Quote
Old 12-12-2011, 10:50 AM   #3
Most of the modern speedos do with a regulator for the receiver,
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 12-12-2011, 11:04 AM   #4
DesertRat's Avatar
Any brushless ESC will pass 1s voltage, the computer and the main MOS-FET bank are independent so as long as there is an external booster or pack to run the computer board it will pass the voltage.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. Losi 22 4.0, CRC Xi (retired), CRC Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 12-12-2011, 11:20 AM   #5
Robudda723's Avatar
Ok, so the booster or receiver pack is not just boosting the voltage for the servo it is also boosting the esc because the computer needs higher voltage to do it's thing. I think i got it now.
Also I seen a diagram on here for wiring a receiver pack for a 1s setup, but can't seem to find it. Anyone have the link?
Also I am running 1/10 pan with 10.5 what receiver pack specs are recommended. life, lipo, mah rating?
Thanks for the info,
Rob
Old 12-12-2011, 03:29 PM   #6
I run Novak- Edge or Havoc Pro SC with X Drive. Both are for 2 cells but I have run them in World GT and Legends with one cell. The Booster works fine with either (Novak). or you can run a reciever pack- LIFE. If you get a Kinectic they like a reciever battery pack (life).
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT-12 Racing USA (21.5 ), Formula 1 and Home Track is 386 RaceWay,ROAR #7540.
BullFrog is offline   Reply With Quote
Old 12-12-2011, 03:49 PM   #7
wingracer's Avatar
Rob
For a Tekin, this is a great way to wire it. With this set-up, you can use pretty much any battery pack, 1s or 2s. I'm using a 200mah 2s lipo with this set-up.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 12-12-2011, 03:50 PM   #8
LMRacing's Avatar
Trader Rating: 27 (100%+)
The LRP has a voltage booster built into it so its the only ESC that I am aware of that can run 1S without a RX pack or voltage booster. It will send 6V to your RX as well so that it has enough voltage to operate properly
LMRacing is offline   Reply With Quote
Old 12-12-2011, 03:54 PM   #9
wingracer's Avatar
Originally Posted by jsinclair View Post
No not all can
Name one that can't. I don't know of any. There are a few that take some different set-ups but I don't know of any racing esc's that can't do it at all.
Team Shepherd USA
Old 12-12-2011, 04:39 PM   #10
kyle133's Avatar
I could not get a Hobbywing Xerun 60A to work with 1S. I had to plug in a 7.4V source in order to turn off the voltage cutoff. I also couldnt get the supercharge software to run with boost and turbo.
I was using a Novak Smartboost, not a RX pack though..
ACTION HOBBIES KINGSVILLE
MT POCKETS RACING
kyle133 is offline   Reply With Quote
Old 12-12-2011, 04:46 PM   #11
wingracer's Avatar
There is the problem. Two LVCs competing. There is always a way.
Team Shepherd USA
Old 12-12-2011, 04:50 PM   #12
kingbee9's Avatar
Trader Rating: 30 (100%+)
i run the 60 amp Extreme Stock speedo with 1S, i use a 800mAh 2S lipo rx pack. you use a 2S pack to turn off the voltage cutoff (you can use the rx pack to do this). then upgrade the software to 508. I ran this combo with boost and turbo at the US Indoor Champs and it worked great.
Brian Wedge
NORCAR R/C Racing at The Gate
www.norcarracing.com
kingbee9 is offline   Reply With Quote
Old 12-12-2011, 04:53 PM   #13
kingbee9's Avatar
The 1S Hobbywing has an internal BEC that doesn't require a booster or RX pack. These are available at Lefthander RC or CRC.
Brian Wedge
Tekin RS/RS PRO on 1s Lipo Q&A Randy_Pike Electric On-Road 1153 12-07-2016 09:18 AM
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
Speed Passion Cirtix Stock CLUB ESC Jochim_18 Electric On-Road 899 09-22-2015 01:09 PM
Around The Table With Paul Lemieux(RC-America/Thunderpower) Paul L Electric On-Road 1384 12-18-2009 09:06 AM
