Old 12-07-2011, 09:13 AM   #1
redron123's Avatar
Trader Rating: 87 (99%+)
Default dremmel attachment for triming wheel wells
I saw some guys at the track recently with a sanding wheel that was about the size of a 1/10 on road wheel attached to their dremel to trim wheel wells. I guess it wasd 1 1/2 -2" in diameter. I have looked around and found nothing. Does anyone know if this is homemade or an attachment that is for something else and works on the dremel?
check it out ----> www.ddatvinc.weebly.com D & D ATV PARTS INC.
redron123 is offline   Reply With Quote
Old 12-07-2011, 09:23 AM   #2
Chaz955i's Avatar
It likely was a touring car wheel. I've seen a few of them at my track. It is just a foam touring wheel with the foam removed and sandpaper glued on.
At The Gate Bizzos
Chaz955i is offline   Reply With Quote
Old 12-07-2011, 09:27 AM   #3
redron123's Avatar
Ok so does anyone know what they were using to chuck it up in the dremel?
Old 12-07-2011, 09:33 AM   #4
liljohn1064's Avatar
Trader Rating: 17 (100%+)
I've got sanding drums that big, it fits a standard 3/8" chuck.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 12-07-2011, 09:37 AM   #5
Trader Rating: 20 (92%+)
Harbor freight, rockler, woodcraft. Any wood working shop or site will sell sanding drums that you normaly hook up to a drill press, you just need to find one with a small enough shank for a dremel... There around and probably cheaper than retro-fitting a wheel. Google drum wheel in the size you want and I'm sure you'll come up with something
RyeRey521 is offline   Reply With Quote
Old 12-07-2011, 10:23 AM   #6
al dente's Avatar
if you take a world gt front wheel that some is done with, true off all the foam. use shoe goo to mount sandpaper. use some old bearings and the cutting wheel attachment. i make them all the time. works great. you can use a 1/12 wheel as well.
Team CRC / Dumper's Speed Shop / Team Scream Racing / Black Art
RC America / FB/FX / Colorado On Road RC Club
5280 Raceway (5280raceway.com) home of the MILE HIGH INDOOR CHAMPS April 19-22, 2018
al dente is offline   Reply With Quote
Old 12-07-2011, 10:27 AM   #7
Logi Maker's Avatar
Trader Rating: 49 (100%+)
Two word Pedi Paws. They carry them at Target and what not..
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\MIP\JConcepts\Schelle\ProlevelRC
Logi Maker is offline   Reply With Quote
Old 12-07-2011, 10:32 AM   #8
Chaz955i's Avatar
machine screw and a nut on the ones I saw.
At The Gate Bizzos
Old 12-07-2011, 10:49 AM   #9
CraigMBA's Avatar
Trader Rating: 22 (100%+)
I use a pair of Tamyia lexan scissors to rough cut the hole, and finish it with this:
http://www.toolmarts.com/Delta/17-940.html
* Cee Lo Dizzle, the Secizzle * Red Bull * Team Homies * Pintura de Negro Mate * USVTA #152
CraigMBA is offline   Reply With Quote
Old 12-07-2011, 11:10 AM   #10
timmay70's Avatar
I use one of these, it also happens to be my most borrowed dremel bit:
Speed Merchant Rev7, Tekin, TQ Racing (wire), Team Tamale
RC Excitement - Buy where you race, support your local tracks.
ROAR #105242
timmay70 is offline   Reply With Quote
Old 12-07-2011, 09:54 PM   #11
redron123's Avatar
I use most of the techniques to cut and trim bodies but i like the idea of having one the size of the wheel at the track to fine tune the trimming when i see it rubbing.
Old 12-08-2011, 12:10 AM   #12
mailboxck's Avatar
A bit crude, but what I do is wrap sandpaper on an old can or bottle that's about the same size as a touring car tire. Then I manually use it to smoothen the wheel wells of my rc body.
mailboxck is offline   Reply With Quote
