Old 12-22-2004, 11:31 AM   #181
TJ Bradley's Avatar
I'm still broke from buying tires for the reedy race.
TRUSource
www.trusourceusa.com www.hotracetyres.com www.teamtekin.com www.teamassociated.com www.racepf.com www.superiorhobbies.com
www.beachlineraceway.com www.schelleracing.com www.p1brand.com
TJ Bradley is offline   Reply With Quote
Old 12-22-2004, 11:39 AM   #182
JLock's Avatar
Rubber tires are still around basically for concrete surfaces. Not all the clubs have the luxury of having an asphalt parking lot to race upon. One of the club track I race upon is rough concrete. We experimented with foam tires and ate up a set in one qualifying run (5 minutes of hard running)!!! Also, foam tires, even treated with traction compound, just will not give you any traction on concrete. Foams on concrete are good for drifting if that is your cup of tea but just will not work on most concrete surfaces. You can use rubber on carpet but have to set up your car radically different than you would with foam tires.
Texas 5
It's not what you know; it's what you can prove.
The only thing that is for sure is that nothing is for sure!!!
The needs of the many outweigh the needs of the few, or the one.
There are 2 things in life that are infinite: the universe and stupidity.
JLock is offline   Reply With Quote
Old 12-22-2004, 12:41 PM   #183
stormperson's Avatar
Send a message via AIM to stormperson
TJ- You going to be at the novak race?
R/C Excitement Special Projects Coordinator
Kwik | Speedmerchant | Parma PSE | KO Propo
Team Pickles
stormperson is offline   Reply With Quote
Old 12-22-2004, 12:51 PM   #184
TJ Bradley's Avatar
stormperson- I have to work during novak so no. I think pritch and i might be going to some carpet race in toronto and then snowbirds.
Are you going to novak and snowbirds?
TRUSource
Old 12-22-2004, 01:03 PM   #185
CypressMidWest's Avatar
Originally posted by AdrianM
Cypress - Thats you opinion. Most carpet racers on Earth run rubber tires. Only a few regions in the US run foam on carpet. Every where else they try to do it it fails. Every major race in Europe is on rubber and no one complains.
I undertsand that the rest of the world runs rubber tires, The entirety of the midwest, as well as the majority of the Northeast can hardly be summed up as a few regions.
I look at it this way, the most HIGHLY ATTENDED Carpet ROADCOURSE only race ON EARTH is Foams only. Kinda makes you wonder doesn't it?
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 12-22-2004, 01:37 PM   #186
Originally posted by Jack Smash
Yeah, Oval. When was the last time you saw a Cup Car with an offroad wing sticking out the back window?
Better yet, when was the last time you saw a 2 door Taurus or Intrepid?
Real Cup racing is even more ridiculous than R/C.
Old 12-22-2004, 01:38 PM   #187
Smile
Old 12-22-2004, 02:06 PM   #188
Jack Smash's Avatar
Trader Rating: 29 (100%+)
Or rear wheel drive? V-8 option? When did the Monte Carlo, Intrepid, and Taurus start coming with a Ford 9-inch rear end and '65 Galaxy front suspension?
Kyosho / Orion / Amain.com / Protek / MIP /
Jack Smash is offline   Reply With Quote
Old 12-22-2004, 03:13 PM   #189
Send a message via AIM to David Alberico Send a message via Yahoo to David Alberico
what's up PW?
David Alberico is offline   Reply With Quote
Old 12-22-2004, 05:11 PM   #190
Entropy's Avatar
So when are the Stratus 3.0 rubber coated foam tires coming out?
Entropy is offline   Reply With Quote
Old 12-22-2004, 06:38 PM   #191
tc1
Trader Rating: 15 (100%+)
Originally posted by turbodog
Is this the Protoform Stratus 3.0 thread?!
tc1 is offline   Reply With Quote
Old 12-22-2004, 10:02 PM   #192
bhambrent's Avatar
When will the 200mm be out?
bhambrent is offline   Reply With Quote
Old 12-22-2004, 10:16 PM   #193
ntc3freak's Avatar
yeah.i can't wait laaaaaaaa
ntc3freak is offline   Reply With Quote
Old 12-22-2004, 10:52 PM   #194
Greg Sharpe's Avatar
Common template bodies aren't necessary in R/C racing, as we don't have telemetry available to measure out every last mph or lateral-G.
However, it might be a good idea if the major sactioning bodies decided upon just a few max/min values. I'm suggesting limits to the front windshield rake, trunk height, roof width, etc. Allowing a range of values for these dimensions gives the designers room to work their magic. As it is, there are already a few rules that do this without any complaint from the masses (ie: max wing height even with roof line).
I agree that normal road going car replicas (ie: many HPI TC sedans from the first few years) are not good looking at speed in a 1/10 scale environment. Whereas the current generation of TC bodies look great, expecially with the paint industry stepping it up in recent years.
Furthermore, since 1:1 TC teams are allowed to masage the body quite aggresively, our body designers should be allowed to do the same (as they have been). The only limit to this masaging should be to prevent situations like funny car dragsters. Limitations should be done in such a way as to still permit the evolution of the shell from one year to the next.
p.s.-Protoform rocks!
Why don't we endurance race more often?
Greg Sharpe is offline   Reply With Quote
Old 12-22-2004, 10:55 PM   #195
JimmyMac's Avatar
Actually we do have telemetry to do this. I know Yokomo (Masami has done this). Plus you have a few things that "we" can buy. Eagle Tree for example.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Best Stratus-Hpi, protoform(orig, 2.0, 3.0) i_got_m8_4_$85 Electric On-Road 5 05-07-2005 02:55 PM
Protoform Stratus 2.0 190mm NEW seamus0g R/C Items: For Sale/Trade 2 01-15-2005 11:54 AM
Protoform Stratus Discontinued??? Hugo Electric On-Road 21 03-22-2004 12:20 PM
protoform stratus 2.0 wing ongbenghui Electric On-Road 6 08-08-2002 04:01 PM
Protoform Stratus 2.0 coolrcdad Electric On-Road 12 07-08-2002 03:19 PM
