Old 11-30-2011, 11:27 AM   #1
YR4Dude's Avatar
Trader Rating: 44 (100%+)
Default Tamiya F1 upgrade question
I have an old Tamiya F102.
Recently I noticed that there are a number of conversion upgrade kits for F1 like the Exotek F1R and Yeah Racing Transformula.
I was wondering if it is possible to use the motor pod and axle from my F102 onto any of these newer F1 conversions. I understand that I'll have to get a newer front end for either but is it just the arms only or do I have to swap the steering knuckles and shafts as well?
Thanks for any help in advance.
YR4Dude is offline   Reply With Quote
Old 11-30-2011, 11:57 AM   #2
If I recall correctly the F102 had a different off-set in the rear pod so the wing wouldn't be centered and neither would the mount for the damper.
Old 11-30-2011, 12:13 PM   #3
YR4Dude's Avatar
Would that be the same for the axle as well?
Anyways you may ask why would I want to swap over those F102 parts. Its because way back then I bought upgrades for the F102. Its got the upgraded finned motor pod plate and a graphite axle. So it would be nice if I can swap at least those parts over to the new chassis.
Old 11-30-2011, 12:29 PM   #4
bakaguyjean's Avatar
Your motor mount with the fins will swap over but I shouldn`t be height adjustable,and the carbon rear axle will swap over but it will not last long anyway. Pm`d you about the cyclone parts.
bakaguyjean is offline   Reply With Quote
Old 11-30-2011, 01:33 PM   #5
The axle is the same but the diff side hub is different...and the F102 motor mount has a different mounting position than the F104 so if you use F104 tires the rear ride height will be too high. F103 tires should be about the right height though.
Old 11-30-2011, 05:35 PM   #6
As has been said, the F102 pod will straight on but the offset is different. The F103 moved the motor over, so the f103 diff joint moves the wheel further away from the gear, so you can't use the F102 plastic wheel mount or the axle the diff runs on. The axle and left side wheel mount is compatible with the F103, your alloy motor mount will also fit on the standard F103 pod.
The only difference are the plastic parts, the F102 knuckles and kingpins work fine. Use the carbon reinforced arms, part number 54153, same price as standard arms and much more durable.
terry.sc is offline   Reply With Quote
1/10 R/C F1's...Pics, Discussions, Whatever... Vyger Electric On-Road 13774 Today 08:08 AM
Tamiya Championship Series Neil Rabara Racing Forum 21259 Yesterday 10:12 PM
Tamiya F104 Pro! NT Electric On-Road 9387 10-18-2017 03:12 PM
