M8--->Voltz killer?
Hi to all fellow racers out there,
I have a M8 which I think is great for me(a begginer). But I despise one fact about the transmitter that is it's batteries usage.. :tire: It drains a lot (I mean a lot)of voltz from my batts(1300mah):( Anyone out there that has the same situation like me??:confused: Thanks and Best Regards, Ken:) |
We just got some GP2300 AA cells in stock. I used them all day yesterday for the first time and even after a full day they are still showing 10.5 volts. Check out our website if your interested.
Try Wallmart. I got 8 for 30$CND so about 20-25$US
Energizer 2300mah nihm cells. BestBUy for some reason sells them for almost double |
Last year at this time I bought Rayovac AA 1800mAh at WalMart. I have been using them steadily for a year now and charge them every other Saturday for 1 hour. They were cheap and they work good.
you will use a set of regular AA each day. buy rechargables at least 2000mah. i bought a 2 wall chargers and four batteries as a package. i bought another 8 batteries as backup. the first set of AA have lasted over a year now.
I heard somebody here in Rc tech forums use a Li-po. That could be the solution..
Originally posted by Speed Demon I heard somebody here in Rc tech forums use a Li-po. That could be the solution.. thats overkill |
Re: M8--->Voltz killer?
Originally posted by Wannabe Hi to all fellow racers out there, I have a M8 which I think is great for me(a begginer). But even to the level of a professional. :D Once you get this problem settled, don think you would ever wanna change to another controller. I personally have been using a M8 for the past 3 years. :D |
Originally posted by dakrat thats overkill |
Originally posted by Speed Demon I heard somebody here in Rc tech forums use a Li-po. That could be the solution.. -James |
I use the GP2100's for 2 full nights before I need to recharge them, after a year of use they are worth the money. I am sure most rechargable batts over 2000 will work well. If you use the backlight I dont know how long they will last, I rarley ever use the backlight on my transmitter.
GP just came out with 2500mah AA cells.. should last even longer! I'm running ten 2300mah cells stuffed into KO Helios. After 3 nights of racing, still at 13.5V :sneaky: Looked at LiPo, but using regular NiMh 2300 cells are cheaper, don't need special charger. And you can use Turbo 35/GFX to charge it at 1 amp for quick bumps. For M8, you should be able to stuff 9 cells in it, and get good voltage for a while.
Originally posted by razzo GP just came out with 2500mah AA cells.. should last even longer! I'm running ten 2300mah cells stuffed into KO Helios. After 3 nights of racing, still at 13.5V :sneaky: Looked at LiPo, but using regular NiMh 2300 cells are cheaper, don't need special charger. And you can use Turbo 35/GFX to charge it at 1 amp for quick bumps. For M8, you should be able to stuff 9 cells in it, and get good voltage for a while. |
Hey guys I don't have an M8 but a 3PK so I don't know the battery configuration of the M8. But maybe someone can still help me with a question I have- my 3PK uses a 8-cell AA side by side config. and I want to use some of those GP2500's, how do I make my own TX packs?
- jaybee |
They have 2500's now? I thought they were only 2300......
-Korey |
