amp draw?
Old 11-28-2011, 06:43 PM
anunaki's Avatar
Default amp draw?
hey guys i need your help how many amps is being pulled in my ofna lx1e geared 51/28 5000mah 60c batteries 6s 2650 motor mamba mons on road set up?speed runs and dragracing guestimations welcome!!
anunaki is offline
Old 11-28-2011, 07:25 PM
anunaki's Avatar
ca'mon guys wheres the experts when you need them?
anunaki is offline
Old 11-29-2011, 04:29 AM
anunaki's Avatar
anybody
anunaki is offline
Old 11-29-2011, 06:39 AM
Skiddins's Avatar
Why do you want to know?
Do a straight line run once, then put the battery straight on charge and see how much you have to put back in.
Skiddins
Skiddins is offline
Old 11-29-2011, 10:15 AM
anunaki's Avatar
Skiddins
not battery amps speed controller amps with the set up
anunaki is offline
Old 11-30-2011, 11:47 AM
Mr RCTech's Avatar
You need to get one of these:
http://www.hobbyking.com/hobbyking/s...eter_100A.html
And install it between battery and speedo.
Look for the amount of voltage drop at X amp draw.
Also, a great way to adjust boost timing, gearing and motor timing.
Mr RCTech is offline
Old 11-30-2011, 12:47 PM
Buckaroo's Avatar
Too many environmental variables to be accurate.
The only way to know for sure is to use a Novak datalogger.
Buckaroo is offline
