Still having heat issues? On 2 cars now
Guys,
This is starting to really get to me, I have 2 TB02's one with the Tamiya RS540 and one with an epic ROAR stock Pro with aluminm heat sink. I was out having some fun last night cool's weather and both motor's are over heating. I didn't think that I have either of them geared to high. The RS540 I am using the middle Spur 58T and a 22 pinion. On the Epic I am using a 55t spur and a 23 pinion. This motor I have had issues with always. I have never had it geared on the 58T spur. All we where doin was some lap's up and down the street. The only way that I can tell there too hot is by touch and no you can't keep your finger on them longer than a sec. All the drive shaft is clear and other drive issues. I thought with the RS540 being a 23 turn it should have handle it better. Just wondering weather you guys have any ideas? MDL |
probably geared to high, but if your just running up and down the street flat out it will get very hot!! try running around a parking lot with a basic track laid out and for 5 minutes then see how hot its getting.
J-P:sneaky: |
So why do you think they are too hot? Actual motor temperature means means nothing if that is all you are evaluating.
The only way to tell if it is too hot is by looking at the condition of the brushes and commutator. if they are discolored the motor is probably overgeared or there is a bind in the drivetrain. In fact I would say that if you can touch your motor for more than a second after your run, you are not working it hard enough. They are supposed to run hot. |
:nod:
Originally posted by Rick Hohwart So why do you think they are too hot? Actual motor temperature means means nothing if that is all you are evaluating. The only way to tell if it is too hot is by looking at the condition of the brushes and commutator. if they are discolored the motor is probably overgeared or there is a bind in the drivetrain. In fact I would say that if you can touch your motor for more than a second after your run, you are not working it hard enough. They are supposed to run hot. |
Exactly Like Rick Hohwart said....... ;)
I would check the gear mesh and make sure that you dont have any binding , does the ESC get hot too? RED
MDL,
Since your in Australia i can relate to this very well, the last 2 race meets i have had ambient temp was about 31-35C track temp had to be over 50C. Everyones motor was comming off the track hot last week, even the chassis of the car was red hot.. Its getting to the point where a fan might be a good idea. I have also been running a rollout 2-4mm less than i would normally use.. |
Its soo cold here, I really don't have a problem at all with my motor temperature. I'd be lucky to run 145 degrees after a race...stock off road 2w buggy. The air temp during a friday night race has been as low as 45 degrees....usually 50 on a regular basis.
yeah, but I think that the comm is getting to hot, I mean a couple of meet's ago there was a temp gun there and it was 85 degree's and this is hotter again. I just thought with the gearing that i have it should be this hot. would a tight diff make it work more?
MDl |
Motor heat doesn't matter to a certain point. If they are fading then something is wrong with gearing or motor setup. Trinity stock motors fade easy, because the magnets tend to demagnitize easier. The magents they use in modified motors are proabbly the best, because they do demagnitize as easy. I agree with Rick Howart fully though. If your motor is cold, your not pushing at hard enough.
-Korey |
