Old 12-10-2004, 03:13 AM   #1
woozer71's Avatar
Trader Rating: 23 (96%+)
Default What ESC To Get
I am after a new ESC but I do not know which one to go for because there is alot of good ESC's out there at the moment. Please give me some suggestions?
Fraser Coast RC Car Club/FCRCCC
VBC D06 / Xray T4 2013
Yokomo BMax2 ver 2 - Tamiya F104 x1
Sanwa MT-4
woozer71 is offline   Reply With Quote
Old 12-10-2004, 03:21 AM   #2
Team Duratrax's Avatar
Send a message via MSN to Team Duratrax
Novak GTX
Team Duratrax is offline   Reply With Quote
Old 12-10-2004, 03:37 AM   #3
cooliomojo-CEBU's Avatar
get the novak gt7....great esc and very similar specs to gtx but cheaper. it has been around for sometime so many are using it so you wont have much trouble for set-up and tech problems.
cooliomojo-CEBU is offline   Reply With Quote
Old 12-10-2004, 04:32 AM   #4
In my opinion.....Nothing at the moment compares to Keyence........
1/8 Scale: Tekno EB-48.2... Tekin RX-8 GEN-2 W/2050kv... Airtronix M11-X Radio... HiTec HS-7954SH Servo...
1/10 Scale: Associated B-5(rear motor)...Tekin RSX Gen-2 W/8.5t... Savox SC-1258-TG Servo
Joe B is offline   Reply With Quote
Old 12-10-2004, 04:43 AM   #5
onebeatuptc3's Avatar
Send a message via AIM to onebeatuptc3
If your range isnt limited, i say go Keyence, I have never heard one bad thing about a keyence, the only thing is they are expensive. After that I would say gtx, I have had a few novak things before, and I would have to say its all top notch stuff. After that, Id got with a KO esc. I heard these are just as good or even better then the gtx. Then lastly i would say the LRP Quantum Competiton 2. These are decent, but I would rather get the ones above first then the Q2 .
Thats just my 2cents.
onebeatuptc3 is offline   Reply With Quote
Old 12-10-2004, 08:43 AM   #6
CRASH's Avatar
Trader Rating: 26 (100%+)
Definetly would go with the KO. Either the VFS-2000 or the new VFS-1. Gives you alot more tuning choices. Not to mention it is tiny.
KO PROPO VFS-1
Later,
CRASH is offline   Reply With Quote
Old 12-10-2004, 08:57 AM   #7
Trader Rating: 70 (100%+)
Send a message via AIM to TexRacer
I would NOT go with a GT7.They were a little weary on performance there for a while and had some "BLOW UP" issue's.
Keyence extreme or Rapida
Novak GTX
Tekin G10Pro+(If your needing for offroad this thing is AWESOME)
Will also fit in some onroad stuff.
LRP Q2(lifetime warranty)
KO VFS-1
All great esc's if money isnt a issue.
If your wanting to stay within a certain price let us know and we will try and name the BEST for that amount.
Goodluck.
I have since been picked up by Tekin.If you need a keyence extreme let me know.I have like 5 of them.
Les
*****Look me up on Ebay. I will have alot of stuff going up as 7/7/2016. User name is Dalracer.**** This is going to be a BIG ONE!!!!!!
Just wanted to say Thanks to RcTech for all these years of Great Information.
TexRacer is offline   Reply With Quote
Old 12-10-2004, 10:06 AM   #8
GMartinez's Avatar
Trader Rating: 85 (100%+)
There are plenty of good ESC you will always hear 10 different suggestions from ten drivers it is always good to see what is being used at the local track that way you will always have someone that can help you in case you have issues.
GT7
LRP2
Ko
GM
ETC
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 12-10-2004, 10:28 AM   #9
Either get a ko vfs 2000 (if you can get one at a good price i'd get that) or get the ko vfs-1 with setting adaptor or a lrp quantum comp 1 or 2 (either one of these 4 speedos are very good).
Chazz
Chazz is offline   Reply With Quote
Old 12-10-2004, 07:56 PM   #10
JayBee's Avatar
Trader Rating: 31 (100%+)
Post
Dude, don't fool yourself... Keyence is the best so forget the rest.
Check around, you won't find a single disappointed customer who bought one; as for the others, well...
- jaybee
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 12-10-2004, 10:06 PM   #11
Hey the blow up issue are a thing of the past, Novak puts out great products and are the only ESC that I use , GT7 works for me, RED
redheat8 is offline   Reply With Quote
Old 12-10-2004, 10:16 PM   #12
Just out of curiousity since alot of people are mentioning the Keyence, whats it do thats so special?
psbarger is offline   Reply With Quote
Old 12-10-2004, 10:46 PM   #13
Default esc
this might not be a fair story about a keyence speedo but, last sunday after our club race I had an undischarged pack so i slapped an 11x2 reedykr in my tc-4 to play a little. what i did not know was the motor had a loose mag.My speedo was a keyence zero extreme. the motor was locked(not when you turned by hand, only when it had power applyed to it.) i thought i had not wired it right so i pulled the trigger twice. on the second pull, i guess it got hot enough inside the speedo to short and it caught fire. I pulled the wires as fast as i could but the esc is burnt totally unrecognizable .
before that happened i had no complaints about that esc. other than it was a little complicated to program. I haven't had this experience with any other esc before so I don't know if any esc is designed to take that kind of load.
sedanaddict is offline   Reply With Quote
Old 12-10-2004, 11:09 PM   #14
Sedanaddict....Im pretty sure that would have happened with any speedcontrol.....give the same situation.........psbarger.......Some of the reasons people like the keyence is that it has the lowest on resistance......there's also no need to run big clunky external power caps or shottky diodes with it.......it's pretty much infintly adjustable, unlike some of the others where your stuck with pre-set profiles to choose from.....and all programing can be done right from the unit....no need for a seperate device to program it........
Old 12-10-2004, 11:24 PM   #15
Send a message via ICQ to tc3Guru Send a message via AIM to tc3Guru
btw which is smaller gtx or qc2?
tc3Guru is offline   Reply With Quote
