Old 12-09-2004, 09:49 PM   #1
Default TC3 Shock Rebuild
Hello all,
I have to rebuild the threaded shocks on my tc3 and i bought the rebuild kit.
But whats the easiest way to get all the air out if them any links on how to or any personal tricks any of you like to use thanks for the help.....
teamray is offline   Reply With Quote
Old 12-09-2004, 10:25 PM   #2
koabich's Avatar
Send a message via Yahoo to koabich
Default Re: TC3 Shock Rebuild
Originally posted by teamray
Hello all,
I use the Ride Air Suction Pump. It basically sucks all the air out of the shock. I believe they are still available from horizon hobbies.
Just follow the instructions and take your time!
koabich is offline   Reply With Quote
Old 12-10-2004, 12:08 AM   #3
Speedie's Avatar
Just take your time and follow the directions in the manual. Make sure you let them sit for a while with the oil in them. Pump them every 10 min or so do this a few times and all the air will be out. Make sure you fill the cap as well up to the threads. If its done right the first time you screw the caps on the shock will not go in at all. Then loosen the cap till a little oil can be pumped out. Do this just until the shock goes in all the way. After thats done Stand all of the shocks upside down on a flat surface and depress them and release them all at the same time. What your doing is finding the slowest one. Take that one, and thats the one you set the others to. One at a time bleed a very little oil out of each one till it matches the speed of the one you kept out. They then should all be perfect and consistant. The only other important thing is that they are perfectly equal in length. Thats how I did it anyhow.
www.victoryhobbies.com Greenbay, Wisconsin
Speedie is offline   Reply With Quote
Old 12-10-2004, 12:09 AM   #4
Speedie's Avatar
INstead of the ride pump I use my wifes food sealer that came with containers they work great.
Old 12-10-2004, 12:14 AM   #5
wagonman72's Avatar
3 words....Yokomo Shock Caps. Get em they work fantastic, they have bleeder screws in them.
wagonman72 is offline   Reply With Quote
how often do you rebuild your shock dampers? TRF-Powered Electric On-Road 16 05-24-2010 07:32 PM
WTB shock rebuild kit fenix R/C Items: Wanted to Buy 0 08-25-2006 03:30 AM
F/S; Losi Shock Rebuild Components NIP Mr T-Maxx R/C Items: For Sale/Trade 3 09-01-2005 08:53 AM
TRF Shock rebuild ratter Electric On-Road 5 02-01-2005 06:13 PM
tc3 shock rebuild kh15 Electric On-Road 7 01-15-2005 01:18 AM
