Zero V Extreme??
#46
u got scanner???
just edit the file so its smaller .......
#47
PM me your email and I'll send you a copy of keyence V Extreme 2002 edition manual
#48
drop mi an email if u need a soft copy of the manual....
#49
Baluga n Phantom:
i alreadi email u guyz the soft-copy of the manual...pls let mi know if u have receive it...
#50
Yes, I've recieved mine. Thanks you & Happy New Year.
#51
Manual
Ijnek,
Thanks alot for the manual. Happy new year!
#52
User guid
Could anyone please e-mail me a copy of the user guide for the keyance z-v. Would i also be right in saying that the higher the drive frq the more top end speed you get.
#53
I have two Zero V Extreme, and from what I notice... there is no increase in speed if you use a higher frequency setting... power will just be easier on the motor (less glazing) and smoother... top end speed should still be the same because you're utilizing the same voltage from the battery...
#54
higher freq=smoother power band
lower freq=more torque...
email mi at [email protected] for the manual...
#55
i got a couple of emails tat i alreadi sent out 2...
for those who wan the manual,pls include the esc's anme in the email subject of mention it in the content...thanx
#56
I also have 2 Keyence V extreme...but..I was messing around with it..now I'm not sure if the setting is riight. Is it possible that I can delete the factory setting on it?
I run stock motor..and I like to get more tourg out of my Monster motor. How can I do that? can some one help.
Thanks.
Thanks.
#57
u can try lowering the ESC freq...it works,but ur power band will not b smooth...
try changing ur gearing...
