Techniques for polishing shock shafts? >
Old 11-23-2011, 04:17 PM
dawgmeat's Avatar
Default Techniques for polishing shock shafts?
Just bought a s411 and I'm trying to improve the smoothness, any ideas?
Thanks in advance
dawgmeat is online now
Old 11-23-2011, 04:23 PM
trerc's Avatar
Trader Rating: 89 (100%+)
If they are coated they need no polishing, if not chuck them up in a Dremel and use some Maas or Wenol they will be like glass. I would also double check the insides of the shock bodies and make sure you don't have a piston rubbing somewhere thru travel...
trerc is offline
Old 11-23-2011, 04:46 PM
dawgmeat's Avatar
Old 11-23-2011, 06:53 PM
jdearhart's Avatar
Trader Rating: 15 (100%+)
On the uncoated shafts, I put them in a dremel and start with 1000 grit and then 2500 grit wet/dry paper. Then polish with whatever polish you choose. Wenol is good stuff, as well as Simichrome.
jdearhart is offline
Old 11-24-2011, 02:50 PM
dawgmeat's Avatar
What about Brasso?
Old 11-24-2011, 03:16 PM
cheehtae's Avatar
cheehtae is offline
Old 11-25-2011, 09:57 AM
jdearhart's Avatar
Originally Posted by dawgmeat View Post
What about Brasso?
I've never tried Brasso.
