Old 11-21-2011, 12:09 AM   #1
Default leaky shocks
I'm fed up with my shocks. I'm running a FT TC4 with the stock shocks, and they leak even though I add green slime onto the o-rings. I applied a generous amount of green slime and it still leaks. It must be the design of the shocks where the oil sits on the o rings and causes the green slime to break up its density. What are the LEAST leaky shocks or shocks that never leak? I'm willing to spend more than $80 just so that I don't have to deal with this nuisance.
iDChuck is offline   Reply With Quote
Old 11-21-2011, 12:23 AM   #2
Kyosho shocks or TRF .
frozenpod is offline   Reply With Quote
Old 11-21-2011, 12:27 AM   #3
where do i find the tamiya TRF? where is the favorite site to order them?
Old 11-21-2011, 12:51 AM   #4
I found some on ebay but are from Hong Kong. Are these counterfeited or is this ok?
Old 11-21-2011, 12:55 AM   #5
R3VoLuTiOn's Avatar
Trader Rating: 27 (100%+)
my ft tc4 has sat on my shelf for a year and hasnt leaked or gotten air in it.
ran it for a month like that before storing too.
have you tried changing the orings or checking for an enlarged opening from a bent shaft?
John Tsang 🏁 VBC Racing 🚗 ORCA RC 🚗 GripworksRC 🚗 MotivRC 🚗 GravityRC 🚗 RC America
http://www.facebook.com/VancouverRRR 🏁 http://www.facebook.com/OvergearedRacing
R3VoLuTiOn is offline   Reply With Quote
Old 11-21-2011, 01:30 AM   #6
Trader Rating: 20 (100%+)
I had leaky shocks before on my HB car. A simple fix I tried was to use a cartridge washer before the o-ring. If the shock binds a little take out the washer and sand it down until the shock stroke is smooth
goots is offline   Reply With Quote
Old 11-21-2011, 01:36 AM   #7
cartridge washer? do you have a part number?
Old 11-21-2011, 03:01 AM   #8
HPI103409 I use them on my TCX with the washer sanded down and on my blitz ese. I am unsure If it will fit on your shock shaft assuming the size is different.
Old 11-21-2011, 03:43 AM   #9
sosidge's Avatar
The TC4 came with the older shocks with the foam compensator and no bladder. These are very easy to overfill, and if you overfill them then the oil will come out the easiest way - through the seal.
If you want to stick with the foam compensator, make sure it is well soaked with oil, and when you fill the shock and assemble it for the first time, check that the damper action is smooth all the way through its travel and doesn't stiffen up near full compression. If it stiffens up, there is too much oil. If it squeaks, there is too little oil.
The optional bladder caps make the shock a lot easier to build and basically the same as the new V2 shocks on the TC6. No need for TRF shocks.
Old 11-21-2011, 03:58 AM   #10
The TC4 shocks are rubbish, the version 3 associated shocks might be ok but kyosho and TRF shocks are the best shocks available. TRF shocks are cheap and readily available may as well use them.
Old 11-21-2011, 04:01 AM   #11
Pro10noob's Avatar
Or use 2 o-rings instead of a damper spacer and 1 o-ring.
Also check the pistonshaftguide for to much play, same on the piston.
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 11-21-2011, 08:17 AM   #12
and do I remove the foam compensator when installing the bladder caps?
Old 11-21-2011, 08:21 AM   #13
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
just buy the vcs2 upgrade kit. then you get the aluminum caps and modern bladder configuration. im gonna try this on my FT NTC3 shocks. the bodies look identical so i dont see why it wouldnt work.
valk is offline   Reply With Quote
Old 11-21-2011, 09:37 AM   #14
sosidge's Avatar
Yes.
Old 11-21-2011, 09:42 AM   #15
buy a Sakura S Zero...
Thats about 125 a car incase ur TC4 anoys u more just switch.
If you love ur tc4 and want to use it, take the Sakura Shock and swap.
If it's Broke Fix it, If it's not MOD it !!!
CillieAcc0rd5o4 is offline   Reply With Quote
Better shocks for sc10 hate the ae leakers Dragonfueled Electric Off-Road 52 04-27-2011 10:36 PM
