Old 11-17-2011, 07:27 AM   #1
Meradin's Avatar
Trader Rating: 19 (100%+)
Default Weight Balance
Where is everyone balancing their cars at, front to back? Even 50/50. More towards the front?
What would the benefit of one or the other be?
Meradin is offline   Reply With Quote
Old 11-17-2011, 09:16 AM   #2
http://users.telenet.be/elvo/
This may be helpful.
Lazer Guy is offline   Reply With Quote
Old 11-18-2011, 02:16 AM   #3
daleburr's Avatar
Generally about 50/50 on most modern TCs, that makes the most out of the grip available.
Going rearwards will create oversteer on the way into the corner but should increase traction under power.
Going forwards will create understeer on the way into the corner and when changing direction, and may reduce rear traction under power.
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 11-18-2011, 05:51 AM   #4
Buckaroo's Avatar
Balance left to right, add weight forward centerline to make minimum weight, drive it.
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 11-18-2011, 07:29 AM   #5
Meradin's Avatar
??? This seems opposite from my thinking. Adding weight to the rear of the car makes the turn in faster? I would like adding weight to the front of the car would give it more traction and help the turning. I have a lot to learn!
Old 11-18-2011, 08:01 AM   #6
Xpress's Avatar
Ford Mustang: Plows into corners and loose off the corner Fr/Rr 60/40
Porsche 911: Loose off power into the corner and planted off the corner Fr/Rr 40/60
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 11-18-2011, 08:17 AM   #7
sosidge's Avatar
As ever with setup there are two things to consider which have seemingly opposite effects.
First is simply the weight distribution. Fundamentally the axle with more weight over it will have more grip.
The second is inertia. The axle with more weight over it will be less inclined to change direction.
In road cars, this inertia is what makes people assume that front-engined cars understeer. In a steady-state mid-corner this isn't true, but it is harder to get that 200kg engine that is hanging over the front axle to go into the corner. The opposite is true of rear-engined cars, which is why the 911 is famous for it's traction within the tyre limits. And why it is also famous as a ditch-catcher once you go beyond those limits.
In an RC touring car where the weight is all within the axles and where the weight distribution changes by less than a couple of percent depending on where you put your 30g of ballast, I can't say I've ever noticed the inertia effect. I just get understeer from a rear-heavy car and oversteer from a front-heavy car.
I can notice the difference between a mid-motor 2wd buggy and a rear-motor 2wd buggy - but that is a car that is softly sprung with 200gm hanging beyond the rear axle.
Others may have different experiences.
Old 11-20-2011, 06:34 PM   #8
I seen people weight their car from each wheel.
iDChuck is offline   Reply With Quote
Old 11-20-2011, 06:53 PM   #9
Mr RCTech's Avatar
Bought this for weighting all my vehicles.
Its the best!
http://www.lefthander-rc.com/catalog...oducts_id=1638
Mr RCTech is offline   Reply With Quote
Old 11-20-2011, 08:08 PM   #10
Suspended
Nice scale ! Droop settings are also key for weight transfer...
bertrandsv87 is offline   Reply With Quote
Old 11-20-2011, 08:46 PM   #11
Meradin's Avatar
Would having too little drrop cause a car to understeer? I was playing around with my recoil (1/14th scale) and I typically run 2mm front and 3mm rear droop. I fugured it was a smaller car so I went with smaller droop settings. The rear of the car seemed pretty planted but the front understeered pretty bad. Never traction rolled once though which was nice.
Would changing the droop setting front or rear help or should I put a stiffer spring in there?
Better than Randy, Adam said so!
Second thought...I don't trust Adams, they make up everything!
"Leave it to Steever", custom paint masks, decals, and paint.
Old 11-21-2011, 03:48 AM   #12
sosidge's Avatar
Well, droop is a different topic than weight balance, but essentially less droop (downtravel) means less grip/more response.
how can i check the weight balance on my car.. help! capturefx Electric On-Road 25 03-22-2013 04:02 PM
Touring Car F/R Weight Balance Thread Owen RaCing Electric On-Road 16 10-19-2010 07:18 AM
Weight Balance chromie Nitro On-Road 9 08-11-2009 07:09 AM
