Like Tree209Likes
Exotek F1R
Old 02-24-2015, 01:26 PM
  #1456
Kwikvdub's Avatar
Trader Rating: 99 (100%+)
Thanks Guys!...... Just making sure..... BTW..... Even 64P??......
Kwikvdub is offline
Old 02-24-2015, 01:46 PM
  #1457
Dan
Dan's Avatar
Trader Rating: 66 (100%+)
Yes, I'm running 64P Kimbrough on my F1R2. I'm slowly switching my other F1 cars to Xenon spurs though.
Dan is offline
Old 02-24-2015, 02:09 PM
  #1458
Kwikvdub's Avatar
Thumbs up
Thanks again!
Kwikvdub is offline
Old 02-24-2015, 06:26 PM
  #1459
MikeR's Avatar
Trader Rating: 15 (100%+)
Originally Posted by kineteks View Post
Any update on shock oil for IFS? Is AWG still a good place to start?
Haven't ran F1 yet this winter but 100k in the new pom dampers feels pretty good.
MikeR is offline
Old 02-26-2015, 09:44 PM
  #1460
The Stig US's Avatar
If anyone is interested in a F1R2 roller I have one for sale. Perfect condition, just ran a few times on carpet. Lots of spares as well. PM me if interested
The Stig US is offline
Old 02-28-2015, 07:12 PM
  #1461
NutDriver's Avatar
Trader Rating: 24 (100%+)
Haven't run the IFS yet, but had a good day with the F1R2 with the standard setup. Broke a servo saver, but the Exotek F104 upper arms saved the day. Dropped the rear end to about 3.5mm with the Associated black springs and the Tamiya "red" center spring. Front at about 5mm. Car was very planted. Could drive STUPID and the car wouldn't complain. Should've rebuilt the diff with antiwear grease because the diff was unloading more than I wanted in the corners. Was able to take the win. Thanks for the input, Wheelz!
NutDriver is offline
Old 03-05-2015, 04:13 AM
  #1462
aussierevo's Avatar
Trader Rating: 14 (100%+)
Can I just clarify the Tamiya Red spring used.
Is it part number 53333 or 53163?
aussierevo is offline
Old 03-05-2015, 04:44 AM
  #1463
I just got my minty fresh SMC 7200 2s... it doesn't quite fit.
I've got some work cut out for me since the IFS totally jacked up the front end alignment! but it should be fired up and running this weekend.
JMURACN is offline
Old 03-05-2015, 05:48 AM
  #1464
CFRacing's Avatar
Hey wheelz do the AWG setup works on carpet on foam tires as well?
CFRacing is offline
Old 03-05-2015, 06:03 AM
  #1465
NutDriver's Avatar
AussieRevo,
I don't know. I got my center spring set from F1RClab. I think he puts the spring package together himself.
Old 03-05-2015, 10:18 AM
  #1466
wheelz's Avatar
I am using the 53163 flo red spring. they are more progressive than the other shorter springs
where are the batteries not fitting into your car?
you are correct that the front needs to be readjusted... the front ball-studs needed to be moved forward to make room for the damper tubes and springs.
I dont have much experience with foam on carpet. I would definitely start with that though the foam tires should have more grip than rubber so I feel like the AW grease handling characteristics would be required to keep the car from diffing out even harder with the increased grip..
wheelz is offline
Old 03-05-2015, 11:25 AM
  #1467
CFRacing's Avatar
Thanks for your quick reply will try it.
CFRacing is offline
Old 03-05-2015, 12:15 PM
  #1468
I filed down some of the carbon fiber so the battery would fit between the servo and backstop. with the IFS bulkhead, the servo cant be adjusted all the way forward to fit the 2s Lipos. not a big deal... 5 minutes with a micro file.
JMURACN is offline
Old 03-05-2015, 12:36 PM
  #1469
MikeR's Avatar
Shorty pack
MikeR is offline
Old 03-05-2015, 12:37 PM
  #1470
aussierevo's Avatar
thanks Aaron for the reply.
Cheers
