Like Tree209Likes
Exotek F1R
Old 06-28-2019, 06:05 PM
  #2716
Trader Rating: 16 (100%+)
That’s a F1R3 with the V2 arms. So it does fit!
astgerma52sp is offline
Old 06-30-2019, 05:55 PM
  #2717
5th wheel's Avatar
Originally Posted by astgerma52sp View Post
Thatís a F1R3 with the V2 arms. So it does fit!
nice but I am running the F1R with the Tamia Front end looking for a low nose body
5th wheel is offline
Old 06-30-2019, 06:41 PM
  #2718
f1larry's Avatar
Trader Rating: 17 (100%+)
Originally Posted by 5th wheel View Post
What would be a good choice for a new body for my F1R that will fit properly. protoform stop making the one I have now . Itís the low nose thanks...
the bitty design type 6R or 6C always fit my F1R3 very well
MikeR likes this.
f1larry is offline
Old 07-01-2019, 05:52 PM
  #2719
5th wheel's Avatar
looks great I like that one. I will get one .if it fits the F1R3 I am sure it will work on the F1R.
Old 07-03-2019, 09:40 AM
  #2720
MikeR's Avatar
Trader Rating: 15 (100%+)
The original F1R? Yes just about any body will fit it because it is so narrow.
NutDriver likes this.
MikeR is offline
Old 07-03-2019, 07:15 PM
  #2721
5th wheel's Avatar
thank you Mike good to know
Old 07-05-2019, 11:20 AM
  #2722
MikeR's Avatar
Congrats to Boris! The 2019 UF1 F2 class winner, piloting the F1R3!
2019 UF1 Formula 2 Winter Champion ? Boris Tsenov | UF1 RC - Formula 1 RC Racing
Raman and 5th wheel like this.
MikeR is offline
Old 07-05-2019, 02:06 PM
  #2723
VegasHB's Avatar
Boris is such a great person. When it comes to tuning questions at 702 he's my go to, super knowledgeable and always willing to another racer out.
MikeR likes this.
VegasHB is offline
Old 07-05-2019, 02:10 PM
  #2724
OVA
OVA's Avatar
Trader Rating: 82 (100%+)
Just what tires or brands are you are using
OVA is offline
Old 07-06-2019, 02:03 AM
  #2725
Mike, any chance you will make a wing to chassis conversion for the F1r3? Does it really impact the car’s handling?
f1larry likes this.
Old 07-10-2019, 05:42 AM
  #2726
5th wheel's Avatar
Default Track width
Mike you said in a previous post that F ones run better at 190 mm. I have some shims now running the f1r original should I bring the rear of the car to 188-189 or 190 it also has the Tamia front end on it. Would it be a good idea to also widen the front as far as possible. I also have the f1r 3 should I do the same to it also it has the new version 2 front end trying to understand the track with these cars thanks for your time and info.. both cars run on gravity tires asphalt track only Outdoors
Old 07-13-2019, 03:29 PM
  #2727
5th wheel's Avatar
Default Track width
I can see how you change the track width with shims and different size bearings in the front how do you change the track width on a F-1 R original do you guys shim out the tires I have no room to put shims on the axle on the rear
Old 07-13-2019, 06:44 PM
  #2728
MikeR's Avatar
I try to match the rear width just to feel balanced. Narrow up front tends to increase steering so it is a tuning option.
MikeR is offline
Old 07-13-2019, 06:48 PM
  #2729
MikeR's Avatar
I space out the rear hubs from the axle with spacers. Or you can perhaps use TC car wheel shims. Just don't forget they may be in the wheels when you swap wheels
MikeR is offline
Old 07-15-2019, 05:35 PM
  #2730
5th wheel's Avatar
Thank you
