Like Tree209Likes
Exotek F1R
Old 03-29-2019, 06:02 AM
  #2701
Trader Rating: 16 (100%+)
No problem with mine. Everything sits flat on the chassis. I did strip the right droop screw within the lower area. I had to install a larger diameter button head screw, which actually works perfectly. I may convert the other side droop screw to a similar screw.
astgerma52sp is offline
Old 05-15-2019, 05:50 PM
  #2702
5th wheel's Avatar
Default Ya !
The F1R still can hang on with the other models of F1s got 3rd
MikeR, jrfoell and aracefan like this.
5th wheel is offline
Old 06-13-2019, 06:52 PM
  #2703
Hi! Got F1R3 Conversion kit (#1570) and IFS Set v2 (#1878), may I ask if IFS Servo mount (#1509) is still needed? Is F1R3 Chassis rail (#1571) a must option too?
Very much thanks!
donatelli is offline
Old 06-15-2019, 06:19 PM
  #2704
5th wheel's Avatar
Very much thanks!
yes on # 1509 ...chassis rail. Only if you like it or run on carpet... I have it on my f 1 r3 I run on asphalt only does good for me.
Old 06-16-2019, 02:54 AM
  #2705
Much thanks!
Old 06-16-2019, 10:41 AM
  #2706
kmas's Avatar
Trader Rating: 65 (100%+)
If anyone is looking to get into a f1r3 I have a nice roller set up with spares and tires. It’s got the aluminum chassis. Pm.
kmas is offline
Old 06-24-2019, 07:54 AM
  #2707
Very much thanks!
May I have some suggestions of F1 bodies to put on this roller? The front bulkhead tower seems to be quite tall.
Thanks!
Old 06-24-2019, 05:11 PM
  #2708
I use the X-ray body with out any issues!
Old 06-24-2019, 09:25 PM
  #2709
MikeR's Avatar
Trader Rating: 15 (100%+)
Yes I've come across bodies that did not fit the rear/side links but haven't had issues fitting bodies over the ifs tower yet... using modern style F1 bodies of course.
MikeR is offline
Old 06-24-2019, 10:57 PM
  #2710
Much thanks! Got a brand new Protoform F26. Will try then.
Old 06-27-2019, 06:04 PM
  #2711
5th wheel's Avatar
What would be a good choice for a new body for my F1R that will fit properly. protoform stop making the one I have now . It’s the low nose thanks...
Old 06-27-2019, 09:01 PM
  #2712
I really wish they’d start producing the f1-fourteen again. Nothing else looks decent and fits the F1R3
Krumpel is offline
Old 06-28-2019, 12:14 PM
  #2713
I am using the Xray X-1 body. With just minor modifications to the side tubes the car the body sits and works flawlessly
Old 06-28-2019, 05:38 PM
  #2714
5th wheel's Avatar
yes I like the fourteen also
Old 06-28-2019, 05:39 PM
  #2715
5th wheel's Avatar
looks nice I don’t think it will fit the F1R ?
