Like Tree209Likes
Exotek F1R
Old 03-07-2019, 06:35 PM
  #2686
Regional Moderator
disaster999's Avatar
Hey Mike,
What is the differences between the V1 and the V2 IFS?
disaster999 is offline
Old 03-07-2019, 07:24 PM
  #2687
f1larry's Avatar
Trader Rating: 17 (100%+)
Originally Posted by MikeR View Post
Hi, No plans for more F1R3's sorry. The TRF103 pretty much has all the same features now that the F1R3 had years ago.
mike,
do you have any plans for any goodies for the Trf103?
Maybe an aluminum chasis😁
robk likes this.
f1larry is offline
Old 03-12-2019, 05:48 PM
  #2688
5th wheel's Avatar
Were do you get the blue bump stops for the new v2 arms.? Do you use longer ball studs to attach them ?
5th wheel is offline
Old 03-12-2019, 09:29 PM
  #2689
MikeR's Avatar
Trader Rating: 15 (100%+)
Originally Posted by f1larry View Post
mike,
Maybe an aluminum chasis��
Nothing really right now sorry.
They are stock parts from the TRF103. Yes use posts or nylon ball cups even
See here
MikeR is offline
Old 03-13-2019, 06:18 AM
  #2690
Trader Rating: 16 (100%+)
Default NEW ARMS
astgerma52sp is offline
Old 03-13-2019, 06:19 AM
  #2691
Look at the difference between the new V2 arms (top) and the older arms!
Old 03-13-2019, 06:20 PM
  #2692
5th wheel's Avatar
Originally Posted by astgerma52sp View Post
very nice like it
Old 03-13-2019, 06:23 PM
  #2693
5th wheel's Avatar
See here
ok thank you.the only ones I see in blue on the trf103 is the 5mm x11mm post .is that it? Looks like itís to long ?
Old 03-21-2019, 12:52 PM
  #2694
idbdoug's Avatar
Trader Rating: 38 (100%+)
Has Exotek considered making a conversion for the team associated F6
idbdoug
idbdoug is offline
Old 03-21-2019, 06:18 PM
  #2695
Regional Moderator
it just feels that this will make the car too wide, esp if you pair it up with the exotek wheels, thats 4mm each side, 8mm total.
Old 03-22-2019, 04:49 PM
  #2696
MikeR's Avatar
No, for todays premounts, that most people are running these days, the wider arms are perfect width. With the IFS;
Gravity/Ride premounts are 189mm wide
Volante fronts are 185mm wide.
CRC fronts are about 188mm wide.
And Shimizu is gone so you wont be worrying about that combo soon....
F1's run better with around 190mm width in the rear so you want the fronts width to come close to that.
MikeR is offline
Old 03-22-2019, 11:56 PM
  #2697
MikeR's Avatar
idbdoug
There could be a new F6 coming. Seems backordered most places...
MikeR is offline
Old 03-28-2019, 09:30 AM
  #2698
Jtipsy's Avatar
Put my v2 kit on last night on my f1r3 chassis with the aluminum chassis plate, the lower screws that go into the rear arm holder were to long at 8mm had to swap out for some 6mm I had in my parts box. anyone else run into this. I measured screw twice to make sure I was using the right screw.
Jtipsy is offline
Old 03-28-2019, 01:50 PM
  #2699
I’m not sure which part you are referring to.
Old 03-28-2019, 07:05 PM
  #2700
Jtipsy's Avatar
The bulk head and the blue aluminum brace that holds the lower arms. The aluminum brace is loose with 8 mm screws had to swap to a 6mm screw for it to snug up before bottoming out
Jtipsy is offline
