Like Tree209Likes
Exotek F1R
Old 12-09-2018, 05:10 PM
  #2641
5th wheel's Avatar
Are you using the X-ray servo saver. I have the same system with no issues.but X-ray has 2 servo saver that almost look a like.are you using the correct one
5th wheel is offline
Old 12-09-2018, 06:04 PM
  #2642
5th wheel's Avatar
What parts are needed to widen the rear or the front of the F104 R3 . I don’t understand how to do this and why you need to. I don’t see any kits for this? Thanks for the information.
Old 12-09-2018, 07:18 PM
  #2643
Trader Rating: 16 (100%+)
No servo saver. Just a servo horn and I already switched out to a different servo but the problem is still there.
astgerma52sp is offline
Old 12-10-2018, 05:35 PM
  #2644
5th wheel's Avatar
Is something bent? Post a picture
Old 12-10-2018, 06:04 PM
  #2645
I have a race this weekend so I took it out of the car in favor of the stock steering setup. I went and inspected the parts and nothing is bent. I guess I give up on it!
Old 12-10-2018, 09:05 PM
  #2646
Do you have a glitch capacitor plugged into your receiver??? It might be a servo not getting enough current/signal around neutral or the torque is too low.....
bertrandsv87 is offline
Old 12-11-2018, 04:48 AM
  #2647
It is possible the servo is glitching. However, wouldn't I notice the same problem with the stock steering setup. I have the stock steering system in the car now and it works perfectly. The servo centers itself even after I manually push the servo towards the left or right. I am convinced the problem is with the Exotek steering rack system.
Old 12-11-2018, 10:52 AM
  #2648
Acid_CZ's Avatar
Is everything moving freely when you disconect the servo? In fact its better to have some play than everything tight. Then it acts as you described.
Acid_CZ is offline
Old 12-11-2018, 12:28 PM
  #2649
When I detached the steering servo link and the links to the uprights the steering system moves left to right freely. There is no bind and or bend in the system. I have taken the entire front clip apart and inspect every part including the pins that hold the arms and nothing is bending or binding. It's a mystery to me why the system stopped working. I am going to send it back to Mike at Exotek. He has offered to help and hopefully he can make sense of it.
Old 12-11-2018, 12:34 PM
  #2650
Old 12-11-2018, 02:38 PM
  #2651
OVA
OVA's Avatar
Trader Rating: 82 (100%+)
Originally Posted by astgerma52sp View Post
I Hope your radio steering is not sticking or weak return spring ?
OVA is offline
Old 12-11-2018, 05:06 PM
  #2652
fat500's Avatar
Trader Rating: 33 (100%+)
Andy is a top shelf racer and knows his stuff.....Constantly posting one of the fastest lap with his exotek ......darn him.......hope it gets fixed
fat500 is offline
Old 12-11-2018, 05:28 PM
  #2653
MikeR's Avatar
Trader Rating: 15 (100%+)
Thumbs up
astgerma52sp emailed us already and he was going to send the rack set back so that I can inspect it and swap anything out that may be a problem.
Leester and 5th wheel like this.
MikeR is offline
Old 12-11-2018, 05:43 PM
  #2654
5th wheel's Avatar
as always great service from Exotek
Old 12-11-2018, 10:20 PM
  #2655
Correct....Hope to hear what the cause of the problem was in the near future....
