Like Tree209Likes
Exotek F1R
Old 11-20-2018, 06:01 PM
  #2626
MikeR's Avatar
Trader Rating: 15 (100%+)
Originally Posted by 5th wheel View Post
trying to get the rear of my F1 R3 to go higher I have the front at five and a half I need to raise the rear of the car the plastic inserts won't get me any higher than 4 and 1/2 is there any other option parts to where I can get the rear of the car to at least five mm or even five and a half run on a bumpy asphalt track rubber tire thanks
Are you using the #2 cam with the bearing on the down setting? Should easily get you above 5mm. Any pictures?
MikeR is offline
  #2627
5th wheel's Avatar
Gravity rc is our track tire. Measuring from the corners of the rear pod in the back and at the side Springs and on the front just under the droop screws by the front knuckles
5th wheel is offline
Old 11-20-2018, 06:12 PM
  #2628
5th wheel's Avatar
yes # 2 sorry no picture yet.its my F1R original My F1R3 I have #0 and it’s at 5mm in the rear.something up here .Rubber tire are some what worn out wood that make a difference? Thank you for any help though I might need new cams
Old 11-21-2018, 02:12 PM
  #2629
CFRacing's Avatar
Quick question, do the X-ray gear dif fits in this car? Thanks in advance
CFRacing is offline
Old 11-21-2018, 07:34 PM
  #2630
MikeR's Avatar
Yes if you use Exotek part number 1862.
MikeR is offline
Old 11-22-2018, 06:43 PM
  #2631
5th wheel's Avatar
well I put on some new tires and my right height is 5 1/2 front and rear.Iím not understanding that with rubber tires. I didnít think it would change on rubber tires .?
Old 11-22-2018, 06:44 PM
  #2632
5th wheel's Avatar
Has that happen to anyone else ? It’s never done that with my touring cars
Old 11-22-2018, 09:40 PM
  #2633
Fredp1's Avatar
Different brands or series of tyres may have different diameter.
Also different inserts may effect the diameter.
E. G I've noticed on the Pit Shimizu going from one series to another may result in different diameter.
Fredp1 is offline
Old 11-23-2018, 05:28 PM
  #2634
5th wheel's Avatar
okay thank you.same tires just new ones. Never notice it before.
Old 11-25-2018, 08:21 AM
  #2635
mavrickf1's Avatar
Default Front suspension and chassis
Does anyone know when the new front suspension will be released plus if there is a new chassis in the pipe line
fat500, egalsim and astgerma52sp like this.
mavrickf1 is offline
Old 11-29-2018, 05:31 PM
  #2636
5th wheel's Avatar
I think it might be a secret shhhhhhh. LOL
Old 12-02-2018, 08:03 PM
  #2637
idbdoug's Avatar
Trader Rating: 38 (100%+)
can you post more pics of how you did your fan mount with fan in an F1? Will your fan mount work on any F1?
thanks
idbdoug
tdu verney likes this.
idbdoug is offline
Old 12-06-2018, 09:56 PM
  #2638
MikeR's Avatar
thanks
idbdoug
Car is torn down now so cannot sorry. Pic is pretty clear though. Just might need to space the wing mount away with shims.
MikeR is offline
Old 12-07-2018, 07:03 PM
  #2639
fat500's Avatar
Trader Rating: 33 (100%+)
What new front suspension? Tamiya compatable?? Mike???? what you got cooking
fat500 is offline
Old 12-09-2018, 06:48 AM
  #2640
Trader Rating: 16 (100%+)
Hello fellow racers. I have been struggling with the F1R3 steering rack system for the IFS over the past few months. The system will not center itself after turning left and right. If I turn left the system tends to deviate the wheels towards the left and likewise if I turn to the right. I have changed servos, use a servo horn instead of a servo saver, disassemble the entire system and rebuilt it per the manual, tried to shim out all the slop and nothing seems to fix the problem. I do not want to go back to the stock steering assembly using the Y shaped servo posts. However, if I am not able to resolve the problem that may be my only option. Any help or suggestions you can provide would be appreciated. I am also going to post this on RC tech to see if anyone has had a similar problem and maybe able to help. Thanks in advance.
astgerma52sp is offline
