Like Tree209Likes
Exotek F1R
Old 11-02-2017, 06:23 PM
  #2476
scirocco14's Avatar
Originally Posted by 5th wheel View Post
On the Exotek upper arms hows the best way to measure the caster and know what degree you are at? I do have the setup station but nothing for caster thanks Jerry
Technically, caster is the amount of camber change from +20 degrees of steering to -20 degrees of steering. So you can measure it that way.
Most setup stations should have a caster measurement on the side of the setup plates where you can compare the angle of the kingpin to the markings on the setup plate.
Mark
5th wheel and Fredp1 like this.
scirocco14 is offline
Old 11-02-2017, 06:42 PM
  #2477
5th wheel's Avatar
Mark
Ok thank you. I do have the markings on the setup plate.but my set did not come with the needles to gauge it by so I got to eye ball it or best guss. I thought there might be a better way.thanks for the information
5th wheel is offline
Old 11-02-2017, 07:20 PM
  #2478
scirocco14's Avatar
I just use a small straightedge and eyeball it by lining up the kingpin to the marks. Should be close enough.
Mark
5th wheel likes this.
Old 11-02-2017, 07:21 PM
  #2479
MikeR's Avatar
Trader Rating: 15 (100%+)
Also, if you use a hinged type camber gauge you can turn it towards the front of the car (face the camber gauge front to back) so that you can measure the caster via the upright pin angle;
5th wheel, NutDriver and Fredp1 like this.
MikeR is offline
Old 11-03-2017, 06:55 PM
  #2480
5th wheel's Avatar
Okay thank you for the help
Old 11-04-2017, 11:19 AM
  #2481
5th wheel's Avatar
Here what I got done so far on my older F1R
Attached Thumbnails Exotek F1R-dsc00099.jpg   Exotek F1R-dsc00098.jpg   Exotek F1R-dsc00097.jpg   Exotek F1R-dsc00096.jpg   Exotek F1R-dsc00095.jpg
Leester likes this.
Old 11-04-2017, 11:22 AM
  #2482
5th wheel's Avatar
If you see anything I missed or could be better feel free to tell me thanks.Now for some body work
Old 11-05-2017, 06:02 AM
  #2483
scirocco14's Avatar
TQ'd, took the win and set new track F1 single lap record and total laps record with my F1R3. This is a REALLY good asphalt chassis. Beat several F6's, and Xrays.
Mark
Attached Thumbnails Exotek F1R-23131922_10214582939266756_2601307069382934826_n.jpg   Exotek F1R-23131874_10214586701120800_4177622439327829392_n.jpg   Exotek F1R-23244341_1717317041620705_7166502576756686902_n.jpg
MikeR, PDR and 5th wheel like this.
Old 11-05-2017, 07:16 AM
  #2484
5th wheel's Avatar
F1R almost done.
scirocco14 likes this.
Old 11-05-2017, 08:01 PM
  #2485
Leester's Avatar
Trader Rating: 22 (96%+)
Mark
Looks like an old Tamiya F103 body you are running. You must be running the battery in line. If so is it a standard sized pack or a shorty? Can you show us your car without the body on it? Curious as to how you have every thing laid out?
Leester is offline
Old 11-06-2017, 07:01 AM
  #2486
scirocco14's Avatar
That is a Team Saxo Legend body. The battery is transverse. The older F103 bodies actually fit the modern transverse battery chassis better than the newer bodies. More room in the side pods.
I run a standard 4200 mah shorty pack.
Mark
Old 11-07-2017, 01:29 PM
  #2487
Acid_CZ's Avatar
Are those Good Year tire decals or is it printed right on the rubber?
Acid_CZ is offline
Old 11-07-2017, 01:55 PM
  #2488
scirocco14's Avatar
Decals, from Brad Palmer at F1RCLab.com.
DECALS - Page 1 - F1R/CLAB
Old 11-12-2017, 01:12 PM
  #2489
5th wheel's Avatar
F1R is now ready to test at the track hope all go's well.
Attached Thumbnails Exotek F1R-dsc00107.jpg   Exotek F1R-dsc00108.jpg   Exotek F1R-dsc00109.jpg
Old 11-14-2017, 03:24 PM
  #2490
RonF's Avatar
I signed up on exotek site with the f1r3 conversion plus adjustable front and rear wing brace, and now its out of stock!! Mike please tell me more is coming!! I'm always late to the show...
RonF is offline
