Like Tree209Likes
Exotek F1R
Old 11-25-2016, 12:40 PM
  #2266
Rick Vessell's Avatar
Originally Posted by idbdoug View Post
what does putting a shim under the front ball end of the side links do??? more entry/exit steering???
idbdoug
Originally Posted by MikeR View Post
I never used it but apparently it frees up the rear of the car for more steering.
It creates rear steer. The car will rotate harder in the middle of the corner. Don't go too far, 1mm shim max. Otherwise the car will screw itself into the ground.
Rick Vessell is offline
Old 11-26-2016, 07:38 AM
  #2267
idbdoug's Avatar
Trader Rating: 38 (100%+)
thanks
idbdoug
idbdoug is offline
Old 11-28-2016, 05:36 PM
  #2268
Regional Moderator
disaster999's Avatar
I finally bought the machined IFS damper rods and oh my god the difference it has over stock. Makes me wonder why the stock ones were included in the first place and not machined ones. Theres so much play in the stock ones I need to add 500k + oil in there just to get any sort of damping in the front.
disaster999 is offline
Old 11-28-2016, 09:17 PM
  #2269
idbdoug's Avatar
this past weekend at Tony Phalen's revenge race held at Tyler RC Complex I was able to win with the F1R3. It was a combined a-main with the WGT-R cars and I don't know if it's normal but the exotek F1R3 was faster than all the WGT-R's as well as the other F1's. This once my 1st race with the new F1R3 improved steering and it made the car drive like a TC.
Can't wait for next exotek upgrade to the F1R3
idbdoug
idbdoug is offline
Old 11-29-2016, 07:35 AM
  #2270
Yeah I thought I had third place wrapped up till I bit the wall. TQ racing still has the F104 parts in stock. I can't decide to try and keep the F1 or get a WGT-r car going.
tim_s is offline
Old 11-30-2016, 07:51 AM
  #2271
MikeR's Avatar
Trader Rating: 15 (100%+)
idbdoug
Great job!
Working on some new soft F1 springs for the top shock
MikeR is offline
Old 11-30-2016, 09:06 AM
  #2272
idbdoug's Avatar
Great job!
Awesome, I'm going to Hudy Indoor Carpet race in January. Will these be available by then??? If not, if you have a test set I would be willing to try them out at the race which will be on the CRC black carpet.
idbdoug
idbdoug is offline
Old 12-01-2016, 02:54 PM
  #2273
MikeR's Avatar
idbdoug
I've been testing the secret soft springs for quite some time but finally went to production last month so hopefully in stock in 2 weeks if they pass QC
MikeR is offline
Old 12-07-2016, 05:38 PM
  #2274
idbdoug's Avatar
I thought I post a pic of the Montech F15 body on my F1R3. The body side pods are not as low as the Protoforms and you have allot body coverage in the back. I used Tamiya Front Wing & 3racing rear wing but now I need try a wing set from montech. Average paint job at the best
idbdoug
idbdoug is offline
Old 12-08-2016, 11:17 PM
  #2275
Regional Moderator
Mike, are there anything in the works on strengthening the trailing arm support post on the IFS to keep them from bending? I didnt realized the 2 support post were not level or standing absolutely straight until looked at the left and right caster and kept scratching my head why its different from left to right.
Ive set the 2 caster adjusting arm to be exactly the same length and one side would have a larger caster angle than the next. Loosening and retightening the posts reveled there was a slight wobble on the post and you can actually see the caster changing around when spinning the post.
Old 12-09-2016, 12:44 AM
  #2276
Hi,
i will be assembling a F1R3 next week and i will need to buy a bodysheel. has anyone used the Bitty design F6C? My mate is using the protoform 14, but in my opinion is too narrow and a bit ugly. Has anyone used the protoform 15?
Cheers
Javier
jimjav is offline
Old 12-09-2016, 01:05 PM
  #2277
MikeR's Avatar
Hmm, wasn't really any plans for it... I've never been asked about replacement posts so have never even heard of that. The posts in fact are placed in a position on the chassis so that the chassis will just flex in big impacts.
I'm using the same posts I first installed about 2 years ago when the IFS first came out and I know I've had some good crashes since then
But you can email for quote on replacement posts to HK.
Different camber will affect different caster, no matter how equal you measure a turnbuckle. Always measure angles at the wheels- there are too many parts between the wheels and the inner mount points to simply measure turnbuckle lengths.
MikeR is offline
Old 12-09-2016, 01:13 PM
  #2278
MikeR's Avatar
Originally Posted by jimjav View Post
Hi,
Cheers
Javier
The Bitty bodies are nice looking but they are pretty big, heavy and tall- a lot like Tamiya F1 bodies. Fine if you are after looks.
For performance the Protoforms are working best for me, either the 13 or the 14. The 15 seems to have been designed for single damper rod F1 cars (Tamiya 102 etc). Guys trying to run them on any of the dual dampers rod cars are mounting the back of the bodies up higher, to clear the damper tubes, and so it just looks awkward I think.
MikeR is offline
Old 12-09-2016, 10:09 PM
  #2279
JS
JS's Avatar
Trader Rating: 70 (100%+)
Anyone tried the PF front and rear wings?
Currently using F60 front and Montech Rear. This combo works great for my setup.
Curious if anyone has any feedback on the PF wings.
JS is offline
Old 12-10-2016, 12:59 AM
  #2280
I've tried both and the front wing will droop like the Tamiya F2012 after a few hits. The rear is nice and has quite a bit of adjustability and height mounting, but even at its highest is not as tall as the Tamiya wings. Otherwise no complaints with the rear. Although I like them to match so I'll probably sitch back to th F60 or the McLaren.
viking44 is offline
