Like Tree209Likes
Exotek F1R
Old 11-14-2016, 01:01 PM
  #2251
razor41's Avatar
Thumbs up
Here is a video of the BRCA (UK) nationals round 2 win..
https://www.youtube.com/watch?v=-JcM...YX2dXn&index=4
We run 4 qualifying rounds and a single 6 minute race. Points scored on race finish only. We use the GRP S2 as a control tyre making for some very close running..
Qualifying result - http://www.eecc.co.uk/results/05-11-...g_Round_04.htm
Race results - http://www.eecc.co.uk/results/05-11-...1_Final_04.htm
F1R3 running so well at the moment!
razor41 is offline
Old 11-14-2016, 02:45 PM
  #2252
VegasHB's Avatar
We're running 25.5t on medium bite carpet and i'm having a hell of a time getting my car easier to drive. It wants to pull pretty hard different directions under hard acceleration. Coming out of 180's it's incredibly difficult to put power down without the car wanting to dart into a wall.
Car is great in higher speed handling and generally handles really well but it's just a monster to drive in comparison to other f1's at the track.
Diff is medium tight to loose, did the quarter trick on the front tires to check tweak. I have the IFS with soft springs, black associated roll springs, use the tamiya AWS grease in the side dampers and front IFS. I'm pretty new to pan chassis so not sure where to look next. More droop, less drop in the pod? Turn the punch down in the ESC? It's just weird to me how the car just wants to dart either direction under acceleration. I know i'm just missing something key in the setup.
Thinking of just starting over in setup if there's a decent medium carpet setup around as a baseline.
VegasHB is offline
Old 11-14-2016, 03:23 PM
  #2253
MikeR's Avatar
Trader Rating: 15 (100%+)
Hi Vegas,
So it's just lacking forward bite? That can be fixed with a few spring changes and correct tires.
You didn't post your set up but basically you want;
1. extra soft rear top spring (lets the pod generate rear forward bite)
2. steel axle (more rear weight)
3. Firmer front spring
4. Try shimizu 75 rear tire with correct sauce (important)
5. Make sure your rear pod is free and not bound up anywhere
Attached is Aaron Lanes winning carpet set up.
Please post a pic of your car and your set up to help us spot any other things to try.
File Type: pdf
MikeR is offline
Old 11-14-2016, 05:14 PM
  #2254
idbdoug's Avatar
Trader Rating: 38 (100%+)
This past weekend at N-Control RC we had the ROAR region 9 championship and I was able to take 2nd with my F1R3.
Thanks again Exotek and I'm looking forward to installing the latest exotek product,
F1R3 steering set
idbdoug
idbdoug is offline
Old 11-15-2016, 07:54 AM
  #2255
VegasHB's Avatar
Originally Posted by MikeR View Post
Hi Vegas,
Thanks, i was following Aaron's setup when building but I did go to a carbon shaft and probably too soft on the front springs which is why it'll want to hook sometimes. I'll tighten up the front and go back to a steel shaft. Appreciate the help, car is awesome, just lost my way a little.
VegasHB is offline
Old 11-15-2016, 08:25 AM
  #2256
Rick Vessell's Avatar
I'll add to what Mike said. Check the pod and side links, you can chase setup around a link car until you pull your hair out because the links are bound up.
Get rid of the TAM grease in the side dampers. I use 10K on black carpet with good results. The TAM grease is too sticky and doesn't let the pod come back to center on corner exit. Probably ditch it in the front too. Try 20K for the front, same reason, the front is compressing on corner entry and not releasing on corner exit. Kind of like having very little front droop so you get a ton of on power steering.
Rick Vessell is offline
Old 11-15-2016, 09:23 AM
  #2257
MikeR's Avatar
Spot on- thanks Rick!
MikeR is offline
Old 11-15-2016, 02:26 PM
  #2258
VegasHB's Avatar
Thanks fellas, i'm finding out very quickly pancars are very finicky with details, every little spacer, spring, grease weight etc have a massive impact on the car.
VegasHB is offline
Old 11-15-2016, 02:50 PM
  #2259
How much the car weighs has an even bigger impact... IFS is usually very heavy(way past minimum weight)...
bertrandsv87 is offline
Old 11-15-2016, 03:40 PM
  #2260
MikeR's Avatar
ummm .... nope. You need the actual product to opine like that Bert.
MikeR is offline
Old 11-15-2016, 03:42 PM
  #2261
MikeR's Avatar
James winning BRCA carpet set up attached!
File Type: pdf
MikeR is offline
Old 11-16-2016, 08:04 AM
  #2262
Yessir! Haven't been able to run much but I'm very happy with the car. Ran back in Sept for the first time in almost 2 years. First time on black carpet too. Ended up Q3 and finished P2 for the day behind Rob King. Couldn't have asked for much more.
Old 11-22-2016, 06:43 AM
  #2263
idbdoug's Avatar
First practice session with F1R3 steering set and the car seemed to have more steering with more direct feedback, can't wait for Phalen's On-Road Revenge race this sunday with the new steering set.
idbdoug
idbdoug is offline
Old 11-24-2016, 08:55 AM
  #2264
idbdoug's Avatar
what does putting a shim under the front ball end of the side links do??? more entry/exit steering???
idbdoug
idbdoug is offline
Old 11-25-2016, 09:36 AM
  #2265
MikeR's Avatar
idbdoug
I never used it but apparently it frees up the rear of the car for more steering.
MikeR is offline
