Like Tree209Likes
Exotek F1R
Old 08-30-2016, 05:01 PM
  #2176
idbdoug's Avatar
Trader Rating: 38 (100%+)
Well, I have one of the Fenix gear diff coming for my F1R3. Will post once i am able to test it
idbdoug
idbdoug is offline
Old 08-30-2016, 09:00 PM
  #2177
Regional Moderator
disaster999's Avatar
Aside from the center damper which I rcmart doesnt carry, am I missing any other item to make myself an Exotek F1R3?
disaster999 is offline
Old 08-30-2016, 11:36 PM
  #2178
You are missing:
-a bearing set
-spur gear
-differential balls
-diff rings
-steering tie rods
-front springs
-rear bulkhead plate (wing mount)
-rear axle height adjusters (Tamiya #58258)
Also, the bearing that comes with the differential housing should be replaced with a thrust bearing.
Since you are purchasing everything separately, I would replace the F104 diff housing (54148) and carbon shaft (54162) with Tamiya #84380. It includes updates of the previous 2 parts and it places the spur gear closer to the centerline of the car, and it also comes with the correct differential rings. The bearing that is supplied with it however should still also be replaced with a thrust bearing.
viking44 is offline
Old 08-31-2016, 12:10 AM
  #2179
Regional Moderator
Thanks!!, Seems like that diff kit is outta stock. Gotta see if my LHS have them or not. Im going to be using the Exotek front suspension kit with the spring dampers so front springs is included in that kit.
I forgot to mention I have F1 spare parts at home so bearings spur gear, tie rods, diff balls are covered. Thanks for reminding me. The rear wing mount and height adjusters I do need to get. Thanks again
Old 08-31-2016, 10:11 AM
  #2180
You'll be ok with the diff halves on your list. I just happened to need a new diff set and I had the option. I've installed the TRFstyle diff on mine but I haven't run it yet. I might not even feel the difference, but it was the same price so why not?
I forgeot you were going with the Exotek front suspension. I'm still using the F104 front suspension on mine.
viking44 is offline
Old 08-31-2016, 04:08 PM
  #2181
MikeR's Avatar
Trader Rating: 15 (100%+)
Originally Posted by viking44 View Post
You are missing:
Good to know
MikeR is offline
Old 09-01-2016, 09:42 AM
  #2182
What size thrust bearing is needed for the diff housing (part number)?
jessele is offline
Old 09-01-2016, 04:33 PM
  #2183
Acid_CZ's Avatar
Originally Posted by MikeR View Post
Sure thing. Aaron uses the included IFS grey spring.
His winning carpet set up attached.
Thank you Mike
Acid_CZ is offline
Old 09-02-2016, 10:54 AM
  #2184
Tamiya 53136:
http://www.ebay.co.uk/itm/Tamiya-531...-/191854951544
viking44 is offline
Old 09-04-2016, 01:07 AM
  #2185
Regional Moderator
What are bearing sizes I need for the rear diff? All I can find are 1280 and 1060 bearing but it doesnt say the size. They seem to be harder than I thought just to find these bearings...
Old 09-04-2016, 04:57 AM
  #2186
Those numbers are the sizes.
1280 is 12mm x 8mm bearing.
1060 is 10mm x 6mm bearing.
terry.sc is offline
Old 09-04-2016, 07:21 AM
  #2187
Regional Moderator
Thanks Terry,
Another question, since the Tamiya diff doesnt use the standard pan car rear diff, regular spur gear would not fit. Tamiya have this spacer (#54215). Is that what you guys generally run?
Old 09-04-2016, 08:44 AM
  #2188
robk's Avatar
Trader Rating: 22 (100%+)
You need the spacer. 3racing also sells them.
robk is offline
Old 09-04-2016, 04:27 PM
  #2189
http://www.tqrcracing.com/shop/produ....asp?p_id=2006
Includes a set of ride height adjusters as well as a spur gear adapter/spacer.
Serzoni is offline
Old 09-04-2016, 07:46 PM
  #2190
Regional Moderator
Thanks, saves me from buying the F104 bulkhead just for the ride height adjusters, too bad they are out of stock on rcmart
