Like Tree209Likes
Exotek F1R
Old 03-11-2016, 02:09 PM
  #1951
MikeR's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Josh-n-ya View Post
You guys using 100k in side tubes? What about the IFS front end dampers? Still the AW grease? My front end always felt so soft. Is that typical?
Oh yes, for the molded ifs damper use awg grease or the new Tamiya TRF friction damper grease- both are good sticky stuff for this and provides good front end damping.
If using the machined ifs damper rods then you can go to the thinner crc blue because the machined rods have a much tighter tolerance. But you could also use the new tamiya friction grease for this too but reduce the amount.
Sometimes when using firmer springs you can go thicker grease but then going softest springs requires thinner grease other wise the dampers are too slow.
MikeR is offline
Old 03-12-2016, 07:09 AM
  #1952
Josh-n-ya's Avatar
Trader Rating: 95 (100%+)
Thanks! Hoping to get some test laps in soon.
Josh-n-ya is offline
Old 03-12-2016, 03:40 PM
  #1953
Josh-n-ya's Avatar
What's the normal caster setting with the ifs front end?
Old 03-13-2016, 10:39 AM
  #1954
MikeR's Avatar
5 to start but increase up to 9 if you need to settle the initial steering. Again depends on the front tire choice...
MikeR is offline
Old 03-13-2016, 10:45 AM
  #1955
MikeR's Avatar
Job well done Aaron Lane! Winner of the hard fought 2016 Tuning Haus Winter Series!
MikeR is offline
Old 03-13-2016, 10:47 AM
  #1956
wheelz's Avatar
thanks mike! I didnt realize that when I got home they gave me the wrong trophy hahahaha I need t trade mine with the winner of GT sedan obiously
I will have a setup posted soon
Aaron
wheelz is offline
Old 03-13-2016, 11:18 AM
  #1957
Cadman1981's Avatar
How do you guys measure caster on F1 cars?
Cadman1981 is offline
Old 03-13-2016, 11:23 AM
  #1958
wheelz's Avatar
Default Carpet Setup
Hi guys,
This was my setup for the tuning haus series!!
Let me know if you have any questions
Aaron
I have to fix the link.. the mikes setup got uploaded for some reason...
File Type: pdf
Last edited by wheelz; 03-13-2016 at 11:25 AM. Reason: I have to fix the link.. the mikes setup got uploaded for some reason...
wheelz is offline
Old 03-13-2016, 11:27 AM
  #1959
MikeR's Avatar
Use a camber gauge, remove front tires and line up with the upright pin.
MikeR is offline
Old 03-13-2016, 11:57 AM
  #1960
MikeR's Avatar
Originally Posted by wheelz View Post
Hi guys,
Aaron
Still showing Mike set up. Rctech must be buggy today
MikeR is offline
Old 03-13-2016, 01:49 PM
  #1961
Root_66's Avatar
Trader Rating: 14 (100%+)
Great run Aaron! You know how to battle for sure. It was awesome driving on your part and the car was dialed as always. Congrats on the win and Mike congrats and thanks for an awesome product. Got to get my F1 back out on the track soon.
Erik
Root_66 is offline
Old 03-13-2016, 07:19 PM
  #1962
Cadman1981's Avatar
I have one more question, what are you guys doing to hold down the battery? I was thinking of putting some sort of felth/rubber tape on edges of my batt so the middle part of the chassis can bend and twist without the batt affecting it...
Old 03-14-2016, 03:33 PM
  #1963
wheelz's Avatar
Default updated setup!!
hopefully this setup link will work!!! lol
Aaron
"I have one more question, what are you guys doing to hold down the battery? I was thinking of putting some sort of felth/rubber tape on edges of my batt so the middle part of the chassis can bend and twist without the batt affecting it..."
I typically leave the battery loose in the car. I never bolt it down solid because it will create a dead spot for flex in the chassis. you can raise up the battery a little bit for the T-bar. It will not hurt it any I don't know that I've ever done it but its not a bad idea!
File Type: pdf
wheelz is offline
Old 03-15-2016, 09:33 AM
  #1964
My asphalt set up
Thank you sir!
tigerbyte is offline
Old 03-15-2016, 11:47 AM
  #1965
Josh-n-ya's Avatar
Aaron
All I'm seeing is a blank set up sheet?
