Like Tree209Likes
Exotek F1R
Old 01-23-2016, 07:55 PM
  #1831
RonF's Avatar
Originally Posted by idbdoug View Post
Can you still use the older F60, MP4, and F104 kit bodies with newer F1R3 car?
idbdoug
Should be able to use an uncut F104 body, as its the same width as a protoform 2015. I have both and compared them, the proto '15 is of course lower profile.
RonF is offline
Old 01-24-2016, 07:37 AM
  #1832
idbdoug's Avatar
Trader Rating: 38 (100%+)
idbdoug
idbdoug is offline
Old 01-25-2016, 08:56 AM
  #1833
Just picked up an F1R3 conversion and before I get to the nitty gritty of chassis setup, I was wondering what users recommend for the front suspension and rear axle cause I'm probably gonna have to cannibalize an F104X1, or get all new parts.
For the local guys, it's going to be run on TQRC's smooth carpet track (if I ever get me shiz together and get out there again).
I'll probably stick to the stock F104 front suspension before getting the Exotek adjustables or the IFS cause it's what I've got available. But for the rear axle, does this chassis work best with carbon or steel shaft? Thanks in advance!
viking44 is offline
Old 01-25-2016, 12:01 PM
  #1834
edonsohc's Avatar
for medium to high bite carpet, i'm told the carbon axle is the way to go. I think Tamiya has discontinued it though. I don't know how or why since i'm pretty sure the new trf102 uses the same axle.
edonsohc is offline
Old 01-25-2016, 01:07 PM
  #1835
wheelz's Avatar
hey guys,
the video was posted from the third main of the tuning haus series at tq. its a 15 minute main but at least you can see how the car performs
https://www.youtube.com/watch?v=0EKUh7ZcJF8
Aaron
wheelz is offline
Old 01-25-2016, 01:58 PM
  #1836
Looks super smooth! I'll need to go throuh your pics on how ya set the front end up. What was the reason for the traction roll?
Boostinswifty38 is offline
Old 01-25-2016, 02:07 PM
  #1837
wheelz's Avatar
I tried a little bit more rear droop to get the car to put more weight on the front end during 180 corners. Turns out I put too much droop and it was rolling over too far on the front end.
wheelz is offline
  #1838
MikeR's Avatar
Trader Rating: 15 (100%+)
Hi All,
New F1R3 set up sheet now online. Thanks to Petite Rc;
http://site.petitrc.com/reglages/exo...SetupSheet.pdf
We may add details later but for now it's a great start.
MikeR is offline
Old 01-25-2016, 04:11 PM
  #1839
Im very curious to see a good setup on the new crc carpet
Old 01-25-2016, 06:18 PM
  #1840
wheelz's Avatar
Originally Posted by MikeR View Post
Hi All,
its a thing of beauty!!!!
wheelz is offline
Old 01-26-2016, 04:58 PM
  #1841
robk's Avatar
Trader Rating: 22 (100%+)
IF you can't find a carbon axle, the 3racing fiberglass axle is almost as light but stronger and like $5
robk is offline
Old 01-27-2016, 03:27 AM
  #1842
British Menace's Avatar
Originally Posted by wheelz View Post
hey guys,
Aaron
Hello Aaron,
Your car works very well and your a very smooth driver.
Have you tried the short wheel base option on the car?
I haven't tried it and was wondering if you had.
Thanks.
Regards
BM
British Menace is offline
Old 01-27-2016, 04:57 AM
  #1843
edonsohc's Avatar
thanks for tip on the 3racing axle. i'll look into that. I've bought some carbon rod and made my own in the meantime. currently testing to make sure they are going to work. so far they seem fine.
edonsohc is offline
Old 01-27-2016, 05:54 AM
  #1844
axle182's Avatar
Trader Rating: 18 (100%+)
Hi guys, I was wondering if anyone else had ever tried this. I am running the F1R2 chassis on tight high grip carpet.
- We run 21.5
- Adjustable front Arms
- 8 Deg Castor
- 2 Camber
- .5 toe out
- Gold front springs
- Short W/B
- Tamiya Center shock - Blue spring
- AE single side shock instead of dampers
- NO sidesprings
- Battery forward
- Pit soft tires front and back CA on outside edge of front tires.
That's the basics of the car. yes it has no side springs at all, the AE damper just slows the rolling from main chassis to the motor pod. I can drive this like a touring car. Drive in deep, set the brakes to almost lock, turn in hard and I never roll over. Fast corners, the car rotates in, grips up, and lifts the inside front wheel. The outside front then rolls to the CA and doesn't grip flip. While it looks really cool doing it, Im amazed the speed I can carry without flipping. The car cuts like a knife on change of direction too.
Just wondering if anyone had tried this. I have had the car set up conventionally, best I had it was with the AE blue side springs. But this no side spring setup is a lot quicker, a lot easier to drive. Our carpet is 80'x3 rolls of ozite med-high grip.
axle182 is offline
Old 01-28-2016, 07:55 AM
  #1845
wheelz's Avatar
Originally Posted by British Menace View Post
Hello Aaron,
Thanks.
Regards
BM
Hi!
Yes I have run it in the past for very narrow and tight carpet tracks.. at higher speeds I feel that the longer wheelbase is more stable when getting out of the sweeping corners. It is a really easy change to try though! I would try it and if you don't think its better its only 6 screws to change it back
Aaron
wheelz is offline
