Like Tree209Likes
Exotek F1R
Old 11-20-2015, 08:21 AM
  #1696
razor41's Avatar
Thumbs up F1R3
I had a few laps with the prototype F1R3 at C.A.R.S here in the UK. Its very impressive guys. The car dealt with the super high grip conditions superbly. It was very stable and carved through the corners with impressive pace. As Mike mentioned the transverse lipo layout is a BIG deal on carpet, especially high grip. It helps prevent diff out when the rear axel tilts.
The trade off is the body shell compatibility but there's a reason Protoform have made their shells the way they have. Pretty much every F1 car out now has a transverse battery layout option. Anyhow the Protoform shells look great, they are lighter and lower. The Exotek factory 2015 car for example with the Jordan livery looks awesome. I shall post a pic of my Williams Martini shell (Protoform F1 Fourteen) soon!
razor41 is offline
Old 11-20-2015, 03:44 PM
  #1697
MikeR's Avatar
Trader Rating: 15 (100%+)
I couldn't have said it better!
Originally Posted by Ph3nyx View Post
very nice . Can i use the pictures for a news on rcf 1 ?
Sure!
Originally Posted by Vyger View Post
Hey Mike! The new car looks good. I need one. With regards to the body, would the Tamiya body (F60 or MP4-24) fit if the side pods were left as is and not trimmed?
Hey Senor! F104 bodies will be too narrow regardless sorry. But F103 bodies should be good (F1R3 does have the short wheelbase option just like the F1R2).
Originally Posted by RonF View Post
Even though I like the protoform body I have, the Tamiya's are more scale. I hope you reconsider this or at least make the F1R2 available again.
Not the answer you want to hear but there will be lot's of great handling F1R2's on the used market after the awesome F1R3 is released
MikeR is offline
Old 11-20-2015, 03:48 PM
  #1698
RonF's Avatar
That is probably going to be true!
But my next question is, can the F1R3 be changed back via a couple parts and the R2 chassis plate?
RonF is offline
Old 11-20-2015, 07:01 PM
  #1699
RonF's Avatar
I just compared my uncut new F104 body and the Proto 15. If left uncut, the F104 body is same width as Proto 15. So that's a plus. May not help for the scale schemes I have planned but at least there is options. Not sure on MP24 as my beat up one is already cut and painted. FWIW...
RonF is offline
Old 11-23-2015, 11:38 AM
  #1700
wheelz's Avatar
Default F1R3
Hi guys,
i wanted to share with you that this last Saturday I won the first round of the Tuning Haus Winter Series using my F1R3. The car was on rails all day and was by far the most consistent car on the track!
i will be posting my updated setup sheet when the car becomes available. Trust me it is worth the wait! Exotek has managed to update an already amazing car
Aaron
wheelz is offline
Old 11-23-2015, 01:23 PM
  #1701
MikeR's Avatar
Great job Aaron!
F1R3 is 2 for 2 so far this carpet season
MikeR is offline
Old 11-23-2015, 01:47 PM
  #1702
Vyger's Avatar
Hey Ron, thank you for sharing. I appreciate it. I've always been a fan of the Exotek F1's and Tamiya F1 bodies. Shame to break them up now.
Vyger is offline
Old 11-23-2015, 02:46 PM
  #1703
RonF's Avatar
Yep, I may have to stick to 'old technology'.... F1R2 and earlier but still Tamiya...
RonF is offline
Old 11-24-2015, 01:58 PM
  #1704
MikeR's Avatar
Great job Aaron!
Race report;
http://www.redrc.net/2015/11/socal-r...es-rd1-report/
MikeR is offline
Old 11-24-2015, 05:18 PM
  #1705
Root_66's Avatar
Trader Rating: 14 (100%+)
Originally Posted by wheelz View Post
Hi guys,
Aaron
Attachment 1331289
Attachment 1331290
YUP. I was there and saw Aaron run. Car was on rails. Nice win Aaron. Great looking car Mike nice work on making an awesome car even better.
Erik
Root_66 is offline
Old 11-25-2015, 12:05 PM
  #1706
scirocco14's Avatar
Question: for the IFS, is there a stiffer spring available than what comes in the IFS kit? I'm running the silver spring and it seems a little bit soft. The other springs in the kit are slightly softer than the silvers, correct?
Thanks,
Mark
scirocco14 is offline
Old 11-25-2015, 12:36 PM
  #1707
A Exotek chassis with transverse battery layout for the TRF102 would be nice too..
Gurneyflap is offline
Old 11-25-2015, 12:41 PM
  #1708
wheelz's Avatar
Thanks,
Mark
You are correct that the silver is the stiffer spring of the set. What hole are you running on the tower and grease in the tubes?
Currently, on carpet, I am running the soft spring in the top hole with 20k oil using the machined damper tube option. You will need something thicker like anti wear grease for the molded tubes.
Aaron
wheelz is offline
Old 11-25-2015, 01:35 PM
  #1709
scirocco14's Avatar
Aaron
Thanks, Aaron. I just today installed the machined damper rods and it makes a huge difference in feel just on the setup board. I have it set on the top hole on the tower for now, with the silver springs.
I haven't run it on the track yet, will do that on Saturday. Then I'll know!
Thanks again,
Mark
Old 11-25-2015, 04:38 PM
  #1710
scirocco14's Avatar
Also regarding the IFS, how low can you run the front ride height without rubbing the carpet?
Mark
