Like Tree209Likes
Exotek F1R
Old 10-25-2015, 08:09 AM
  #1666
Im very curious: what would me moving the esc forward and the battery back do? I have batt foreard esc back just to save length of wires and weight but if thats not gonna handle well, i wanna fix it before the fourth round of qual
Boostinswifty38 is offline
Old 10-25-2015, 08:38 AM
  #1667
wheelz's Avatar
[QUOTE=Boostinswifty38;14237222]Im very curious: what would me moving the esc forward and the battery back do? I have batt foreard esc back just to save length of wires and weight but if thats not gonna handle well, i wanna fix it before the fourth round of qual[/QUOTE
I have weighed my battery and esc and per mm mine are the same weight. So the only difference is the weight of the wire. Typically I ran my car servo, receiver, battery, esc, motor.
My diff gear won't spin if I hold the wheels down but say if I hold the spur gear and turn one of the tires, there is a good amount of drag from the diff. I can't run my diff loose with the spur gear locked down. The car won't exit the corner well. I wish that there was a torque setting I could give you for the diff nut haha it would be so much easier to describe
In regards to the side spring: compressing the spring will numb the car some and taking preload away typically quicken up the turning and twitchiness.
What tires are you running? I run shimizu 74/75 on carpet but I am only saucing the inner third of the front tire.
wheelz is offline
Old 10-25-2015, 10:46 AM
  #1668
71/72's on the car. Battery rearward and electronics up front helped. Need a twitch more steering so im trying standing the front shocks up to yhe top hole. Still black sidesprings.
Old 10-25-2015, 09:45 PM
  #1669
MikeR's Avatar
Trader Rating: 15 (100%+)
Using an F103 style thrust washer vs the F104 bearing diff thrust has been known to help cure 'diffing out' as you have described it. The F103 style has more differential resistance which may help just on carpet.
MikeR is offline
Old 11-03-2015, 04:58 PM
  #1670
Paco1001's Avatar
Check your e-mail Wheelz
Paco1001 is offline
Old 11-04-2015, 12:58 PM
  #1671
edonsohc's Avatar
what's a good diff lube to use?
edonsohc is offline
Old 11-04-2015, 01:06 PM
  #1672
wheelz's Avatar
are you running 21.5 or 25.5?
I always use team associated clear diff lube on asphalt.. for 21.5 carpet you may want to try tamiya or 3racing's anti-wear grease applied to every other ball.
25.5 lately I have just been using team associated diff lube on both carpet and asphalt.
wheelz is offline
Old 11-04-2015, 01:30 PM
  #1673
edonsohc's Avatar
I'm currently running 21.5 on carpet. I think we are going to 25.5 though. thanks for the input.
edonsohc is offline
Old 11-05-2015, 01:33 AM
  #1674
I would go for a slightly harder centre shock spring.
buzz777 is offline
Old 11-05-2015, 01:38 AM
  #1675
It will give you overall less steering and better rear traction and stability. Practically an easier car to drive. Remember that the rear wheels do everything in F1 - acceleration and breaking - so if you use the added rear traction well and make up for the lost steering by say applying sauce to the front wheels or a softer front spring or a different front tyre, it would mean more overall traction.
A very important gain is that it will take longer to kill your rear tyres!
buzz777 is offline
Old 11-05-2015, 01:42 AM
  #1676
Your setup sounds pretty close to what I run. But one main difference i read was that your diff is loose. I run a pretty tight diff on carpet to get better drive off of the corner. I think that would solve a lot of the issue. You can also play with your side spring compression. Compressing the springs will numb the car and make it rotate less. But I would definitely try tightening the diff down
Aaron
+1
buzz777 is offline
Old 11-06-2015, 08:41 AM
  #1677
liljohn1064's Avatar
Trader Rating: 17 (100%+)
has anyone tried another brand of lower arms and front end parts other than the Tamiya?
liljohn1064 is offline
Old 11-06-2015, 08:52 AM
  #1678
idbdoug's Avatar
Trader Rating: 38 (100%+)
Use kyosho diff grease's
idbdoug
idbdoug is offline
Old 11-06-2015, 08:55 AM
  #1679
idbdoug's Avatar
My front end has the entire exotek upgrades. About $100 for entire upper and lower parts but money well spent
idbdoug
idbdoug is offline
Old 11-06-2015, 10:05 AM
  #1680
idbdoug
I'm missing the IRS and upper links, but thought I'd do a 190mm with a different lower arm set.
