Old 11-13-2011, 07:37 PM   #1
wildman's Avatar
Send a message via AIM to wildman
Default Transponder not counting?
I have been running this transponder for a few years. Under power in the sweeper it misses every other lap? I changed out the transponder, servo, rec, speedo and booster. Everything but the motor. It only counts about everyother?
Transponder is mounted in the front of my 1/12 scale.
Im running a booster and tried to power the transponder direct to a small lipo rec pack and it still missed laps?
Any idea's ...im at a loss?
Brian
wildman is offline   Reply With Quote
Old 11-13-2011, 07:51 PM   #2
Trader Rating: 217 (100%+)
Are you the only one having this issue? You even tried a different transponder and still does it? Sounds like the scoring system maybe at fault. Are they running a newer version of scoring? Your transponder may be too old for the newer stuff.
Andy Koback is offline   Reply With Quote
Old 11-13-2011, 07:55 PM   #3
wildman's Avatar
Yes my transponders are at least 5 years old. I was the only one having issues. Not sure how new the system is? I have never had this issue...
Old 11-13-2011, 08:17 PM   #4
Check for frayed wires and look at the plug that goes into the receiver. Does the light stay on solid or flicker? I take it your running one cell? Make sure you have enough battery voltage. Don't know what else could be happening!
Old 11-13-2011, 08:35 PM   #5
HarryLeach's Avatar
Send a message via AIM to HarryLeach
How high above the track is the transponder? Or, if the track has a scoring bridge, what's the separation between the transponder and the timing loop?
Sounds like a weak connection or frayed wire somewhere if it does it with a dedicated battery as well.
Privateer racing lots of stuff.
Remember kids, racing isn't fair!
HarryLeach is offline   Reply With Quote
Old 11-13-2011, 08:44 PM   #6
Just send it back to AMB for service. Just send mine back few months ago and their customer service is really good.
http://www.gpm-parts.com
gpm-parts.com is offline   Reply With Quote
Old 11-13-2011, 08:59 PM   #7
wildman's Avatar
no frayed wires. I tried two different transponders and it did the same thing? In the main I ran a rec pack direct to the transponder and it missed almost every other lap?
Could the motor cause and issue? Both of these transponders have never failed before?
Old 11-13-2011, 09:08 PM   #8
mailboxck's Avatar
Why don't you have another guy try out your transponder on track? Let them mount it on their car and see if the problem persists.
mailboxck is offline   Reply With Quote
Old 11-13-2011, 09:21 PM   #9
FauxMako's Avatar
Is it counting every other lap? It's possible that you running below the tracks minimum lap time.
Mike
3 3Racing Sakura Zeros: Mustang Boss VTA // Lexus LFA USGT // MazdaSpeed 6 TC
Mini M03 & M05
Life is better with a soundtrack
FauxMako is offline   Reply With Quote
MRT Transponder question. leerjet1 Radio and Electronics 20 02-27-2014 07:37 PM
Transponder not counting HELP! KevinHawk Radio and Electronics 9 03-24-2010 05:39 PM
My laps are not counting! Help fazznick Electric Off-Road 11 01-21-2009 12:06 PM
