Old 11-13-2011, 09:05 AM   #1
Robertcooper88's Avatar
Trader Rating: 15 (100%+)
Default RevTech 17.5 Bad Motor????
I have a RevTech 17.5 I am running in 17.5 Boosted. I am experiencing a major drop off in power one minute into my runs sometimes a little longer. I have used different batteries, tried different ESC setups. Has anyone ever experienced this before?? Can a bad motor act this way? Any help is appreciated.
DischargeRC.com - Race-Opts MTS T2 - TRINITY FOR POWER
Robertcooper88 is offline   Reply With Quote
Old 11-13-2011, 09:58 AM   #2
wingracer's Avatar
Trader Rating: 24 (100%+)
It would help if we knew more. Are you running boosted? TC or 1/12th? Tekin? Settings?
In the absence of more info, too much timing can cause this.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 11-13-2011, 10:18 AM   #3
cwoods34's Avatar
Revtech are better in blinky. A D2/3 loves boost.
And just because you can time it past the last timing notch doesn't mean you always should!
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 11-13-2011, 10:19 AM   #4
I am running boosted. Running the speed passion speedo. .2 delay, 41 boost, 17 timing, 9 punch, 12 slope, 6 neutral. 1 tick of timing on the motor.
This setup is very close to setup used at the beat heat race. Although it could be speedo settings, but at 1 minute or so into a race? I was just wondering if anyone else had experienced this before. I am running 1/10 TC.
Old 11-13-2011, 11:12 AM   #5
Kenny L's Avatar
Trader Rating: 16 (100%+)
I've been running ReVtech in 17.5 boosted 12th scale and have found it to be great motor. Find you need to run can close to 0 line no more than 1/2 line and stretch out your rpm range when using Tekin boosted software.
Team Tekin, Ko Propo America
Kenny L is offline   Reply With Quote
Old 11-13-2011, 11:13 AM   #6
Buckaroo's Avatar
As already mentioned, the Rev motors don't really tolerate ESC boost AT ALL, and are showing their shortcomings with mechanical timing as well. They have a bad habbit of acting just like yours, just before they let all the magic smoke out.
D3 for boosted, Rev for blinky.
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 11-13-2011, 01:33 PM   #7
Thank you! I am putting the D3 in.
Old 11-13-2011, 09:08 PM   #8
These motors have a 30 degree sensor board in them,so if you set timing marks to 0 you will have 30 degree motor timing.This is not good for any motor if you add alot speedo timeing on.Your motor should run alot better if the motor timing is in the negative area ( say 3 marks past 0 towards negative )
mcb-jet is offline   Reply With Quote
Old 11-13-2011, 09:44 PM   #9
B4james's Avatar
They also have a known issue where the motor binds up due to to tight a tolerance, which gets worse when warms up.
Fix is to undo the can screws and put a drop of thread lock on ends and then tighten up only till snug (not fully tightened)
Follow me on Facebook - James Ainslie Designs or on Instagram - JA_Designs
*HEI International for Protoform/Proline/Spaz Stix
*Bitty Design Australia for Bodies and Liquid Mask
* Airbrushmegastore.com for all paint and airbrush supplies
B4james is offline   Reply With Quote
Old 11-15-2011, 01:26 PM   #10
godzukihop's Avatar
Trader Rating: 31 (100%+)
I purchased a new 17.5 RevTech last week and the sensor board was bad. Zero I mean no track time what so ever and it was bad. From what I hear I am not the only one with this issue.
JOHN's MOBILE RACEWAY | 180 RACEWAY | Jackson RC Track
Murnan Modified because HP is intoxicating!!! | VP RACE FUEL |
G-FORCE HOBBIES | Fordham Hobbies | ASHFORD HOBBY | TEAM CAMDEN
RC AMERICA / XRAY / HUDY / TEAM POWERS
godzukihop is offline   Reply With Quote
Old 11-15-2011, 02:28 PM   #11
At our track the Revtech 17.5 is a missle in the boosted class...fastest thing on the track.
Old 11-15-2011, 04:01 PM   #12
stiltskin's Avatar
Trader Rating: 102 (100%+)
At our track, the Revtech 17.5 WAS the fastest thing on the track. Right up until the point where it melted down at 168 degrees. I had about 30 minutes of run time on it when it gave out. I was very impressed with the performance. Great feel, very smooth and powerful, but POOOOOF.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 11-15-2011, 04:42 PM   #13
ShaunMac's Avatar
Common tale my friend.
ShaunMac is offline   Reply With Quote
Old 11-15-2011, 05:19 PM   #14
trerc's Avatar
Trader Rating: 89 (100%+)
Seems like it, I was looking HARD at one of these and opted to just buy another DUO 3, Glad I did...
If it smells burnt up.. it's more than likely hot.. you don't have to touch it..
trerc is offline   Reply With Quote
Old 11-16-2011, 12:03 PM   #15
Hi guys. I'm new to this forum and live in South Africa. not to sound stupid, does this mean that each line on the motor is equal to 3 degree timing? If so, that means I'm running my motor 21 degree timing. My motor temp is 77*C. So far I have had no problems with it.
Gerrie is offline   Reply With Quote
Reedy Sonic Geberit Electric On-Road 775 01-13-2018 11:43 AM
Trinity and ReVtech Motors discussion Mike Blackstock Team and Company Discussions 726 01-08-2018 07:09 AM
Kyosho Ultima SC-R Thread zanernator Electric Off-Road 5024 01-04-2018 01:03 PM
Capital City RC, carpet returns to Richmond, VA wingracer Racing Forum 111 01-05-2012 10:31 AM
