Old 12-06-2004, 12:30 AM   #1
Unhappy Glitching
Does anyone know how to solve this problem?
i have encountered a very serious problem with motor glitching problem when i using laydown brush 23t motor on my local track, my motor is the fastest among all others and i my car will glitch like crazy, it same to others guys who using laydown brush motor.
does anyone know the cause of the glitching?
Newbies is offline   Reply With Quote
Old 12-06-2004, 02:10 AM   #2
pink pac man's Avatar
glitching as in throttle glitching or steering slitching cos if its throttle glitching then it might me you comm is outa shape and the brushes r bounsing and if its stering glitching u gotta hole lotta thing that could be.........ill let sum 1 else do that 1
pink pac man is offline   Reply With Quote
Old 12-06-2004, 02:25 AM   #3
adamkerrnz's Avatar
cut your comm and replace your brushes. add some of those little noise reducing cap thingy's. i cant remember what theyre called
adamkerrnz is offline   Reply With Quote
Old 12-06-2004, 04:02 AM   #4
Default glitching,...... the eternal RC'ers nightmare
I had amoajor problem with glitching that took me months to work out. what i ended up doing was :
1, adding extra little capacitors (3) and not relying on the ones that come pre installed on most motors. ( + to can, uswe the hood screws - to can, and + to- can. they only need to be about small.)
2, keeping a close eye on the comm diameter, and if it gets down to about 1/2 its original diameter, REPLACE IT
3, after every run i now take as fine file to the leading edge of both + and - brushes.
4 re wired the car with new 14g deans wire. (not sure if this actually helped, but my car needed it anyway.!! )
5, shortenbed the wires from me reciever to servo, and rec. to speedy.
6, try differeent positions to mount the reciever, and if possible the speedy
7, i tried some ferrite magnets over the motor, &/or the battery wires. (didnt help me, but i know some people who haved benifited by this, try the Yokomo noise reduction kit)
8, try somone elses reciever,
9, if none of these work, well then i dunno!! have a beer or 3 and worry about it later?!
see how you go
Good Luck
Xray T2 09 (still) - LRP - MuchMore - Futaba 3PK (still)
Bluey_74 is offline   Reply With Quote
Old 12-06-2004, 04:59 AM   #5
why did u use 14g wire.......12g is thicker and better
Old 12-06-2004, 09:16 PM   #6
Smile
pink
it's throttle and steering both glitch.
thanks guys, i will try the you guys advice me.
Old 12-06-2004, 09:25 PM   #7
GMartinez's Avatar
Trader Rating: 85 (100%+)
Make sure that your wiring is not zipped together someitmes that will aslo cause glitching & especially when your receiver is to close to the ESC
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 12-07-2004, 02:46 PM   #8
Default wire
only cos i had some in my pit box, it was new stuff i had sitting round.
No other reason.
Newbies :
see if you can try someone elses servo. if there is a problem on the circuir bard , or with the motor odf the servo it may also be contributing to this.......
CAREFULLY take the servo apart, make sure all the connections r still intact, and clean off the parts with some motor spray.
You will probably find that glitching isnt just caused by one thing alone.(normally) It will usually be lots of little things. So if one fix doesnt work totally, dont give up.
Old 12-07-2004, 04:30 PM   #9
adamkerrnz's Avatar
twist your motor wires around eachother
also make sure your aerial isnt touching any carbon fibre (past experience :S)
Old 12-07-2004, 08:23 PM   #10
Team Duratrax's Avatar
Send a message via MSN to Team Duratrax
Do you have any capacitors on your motor? if you dont solder some on and it will reduce glitching
Team Duratrax is offline   Reply With Quote
Old 12-07-2004, 10:02 PM   #11
Talking
Thanks guys
i will try all the method you guys teach me, step by step
hope can solve it by the end.
glitching help! aus jd 2703 Electric On-Road 6 05-24-2007 05:43 PM
GTB Glitching Vegaspilot Electric Off-Road 4 06-11-2006 10:28 AM
Glitching Help CraigHandley Australian Racing 6 02-29-2004 11:56 PM
Glitching on my 3PK FUK_WRX Electric On-Road 10 08-15-2003 09:50 AM
glitching tdragon Electric On-Road 10 06-17-2003 11:03 AM
