Old 12-05-2004, 05:53 PM   #1
JDXray's Avatar
Send a message via AIM to JDXray
3PK and GTX problem
My bro is having some trouble with his new 3PK and GTX...
The radio and esc turn on fine, but when he wants to set-up the gtx it doesnt want to. What i mean by it not wanting to is when i hold the gtx button down and turn on the esc (the transmitter is already on) it says its supposed to turn red to go into setup mode. The light does come on but then the green one comes right on and i cant set it up.
The car has charged pack and a stock motor, i have tried other motors and it still doesnt work, so i guess it cant be the motor.
Could someone help me and my bro out please.
Jon
JDXray is offline   Reply With Quote
Old 12-05-2004, 06:41 PM   #2
onebeatuptc3's Avatar
Send a message via AIM to onebeatuptc3
make sure that the leads that go from the esc to the reciever are placed correctly, because my friend got a new reciever and wired in his novak wrong and everytime he would go to setup the esc, the thing would turn off.
onebeatuptc3 is offline   Reply With Quote
Old 12-05-2004, 06:42 PM   #3
JDXray's Avatar
Okay will try it now.
Old 12-05-2004, 06:52 PM   #4
JDXray's Avatar
Okay i tried a different radio (my M8) and the GTX works..... When i try it with the new 3PK is doesnt....
Old 12-05-2004, 06:54 PM   #5
adamkerrnz's Avatar
mabe it has something with the 3PK's modulation or HRS system!?
otherwise thats a bit weird
adamkerrnz is offline   Reply With Quote
Old 12-05-2004, 06:56 PM   #6
JDXray's Avatar
Maybe its that new HRS system.. Does the 3pk only work with the hrs recievers?? i have other futaba recievers i may want to try that and see whats up.
Jon
Old 12-05-2004, 07:02 PM   #7
I had a similiar problem and after emailing novak they told me to set the throttle trim all the way up, But I cant remember if it was either all the way brake or throttle. Only my problem was with a dually not the gtx. And I do mean the trim, not the EPA.
stumper is offline   Reply With Quote
Old 12-05-2004, 07:03 PM   #8
JDXray's Avatar
I could give that a try, they said something about a 7:3 ratio or 70 throttle and 30 brake or something, but i'll try your thing right now and let you know..
Old 12-05-2004, 07:06 PM   #9
JDXray's Avatar
It didnt do anything...
When i press the setup button it blinks red and goes straight to green....
Old 12-05-2004, 07:45 PM   #10
best bet would be to email novak . They answered me the same day.
Old 12-05-2004, 07:48 PM   #11
Some other guy is having the same problem in the off road forum, its under something with 3pk in the title.
AE Racer is offline   Reply With Quote
Old 12-05-2004, 07:50 PM   #12
The 3pk will work with Futaba FM, PCM, and HRS recievers, and also Hitec recievers. You have to change the mode to use a different type of reciever though. I cant remember what its called, but just go through the menus and you'll have no problem finding it.
Old 12-05-2004, 09:04 PM   #13
pink pac man's Avatar
ok thats really od cos ive bin using my 3pk with a dually 4 about a year......and im upgrading to a gtx in a few weeks so this had betta not happen to me
ill report back when i get it and tell yous how it went
pink pac man is offline   Reply With Quote
Old 12-06-2004, 01:14 AM   #14
JimmyMac's Avatar
I have a GTX and it works just fine with my 3PK in HRS mode. However... I'm not sure if Drag Brake works. I tried setting it up like the instructions, but when I'm done setting it.. all the lights are on when under normal operation (instructions say it should only be red light). And if I turn off Drag Brake.. then it's back to normal with the red light on under normal operation. So I dunno. But other than that.. the ESC operates just fine.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 12-06-2004, 04:59 AM   #15
JDXray's Avatar
Did you set your gtx exactly to the manual? I have tried this and still doesnt work... I'll keep trying.
Jon
ESC PROBLEM ghj1997 Electric Off-Road 13 06-04-2008 08:38 AM
Problem RaceANissan616 Nitro On-Road 20 07-23-2006 09:07 PM
KO PRO PO VSF-1 PROBLEM mazmo Australian Racing 4 07-24-2005 07:38 AM
New to R/C and I have a bit of a problem ZeeBMaN Rookie Zone 6 05-15-2003 05:08 AM
