Old 03-20-2013, 01:46 AM   #181
dark's Avatar
Originally Posted by RC Infos View Post
Hello
I think E4RS II Evo
It's not definitely defined, but it seems that an upgrade kit would be also available.
great news, I hope in upgrade kit
Sworkz S350BK1 - WERKS B6 - Futaba BLS - GRP - Futaba 4PK - RcAllStickers - Meccamo fuel
dark is offline   Reply With Quote
Old 04-08-2013, 08:50 PM   #182
Default Top Deck options
Anyone know any other top decks that fit this car?
duckman996 is offline   Reply With Quote
Old 04-08-2013, 10:57 PM   #183
Hello
Team Magic 2mm
Kfactory 2.3mm
Kfactory 2.5mm
That's all
RC Infos is offline   Reply With Quote
Old 04-09-2013, 11:30 AM   #184
Hello
Team Magic 2mm
Kfactory 2.3mm
Kfactory 2.5mm
That's all
Great - any suggestion on where in North America these items are available? (The K Factory versions)
Old 04-10-2013, 11:26 PM   #185
Hello
As Amain Hobbies sell the E4RS II in USA, they are probably able to order Kfactory parts (Kfactory is a brand of Team Magic)
Old 04-15-2013, 02:58 AM   #186
moxford's Avatar
hi,
just picked up an E4RSII roller. It has 104t spur, what size pinion should be run in this as a good basis. I tried my 39t pinion out of my Cyclone in the E4RSII, and the pinion was rubbing on the top deck. Motor is 3300KV
Team C T8E, Hobbywing XE-Run 150A ESC and 2200KV sensored motor
moxford is offline   Reply With Quote
Old 04-15-2013, 06:55 AM   #187
Pro10noob's Avatar
3300KV motor sounds like a 10.5T.
What do you want to run then?
Blinky?
Boost and turbo?
This is a bit little information to determin what FDR you want to run.
If it is blinky, start with 5.5 on a medium size track.
If you want to run boost then go up to FDR 6 and start driving the car and temp the motor after 2 or 3 minutes of running.
I have run the E4RS(old one) with a FDR of 7.5 with a 13.5 full open with turbo and timing.
Did go like a rocket and temps of motor where in the 75 degrees celcius range.
Regards Roy
Originally Posted by moxford View Post
hi,
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 04-15-2013, 03:48 PM   #188
Trader Rating: 25 (100%+)
I have been racing my ERSII boosted for a while know. The FDR you should be looking for is around 6.81 to 6.18 on 10.5T depending on your track size and configuration. I do recommend to have 0 timming on the motor, specially on the Trinity Epic 3.5. I have raced with the SP MMM motors with the standard timming (11-20 degrees) with great results. The max temp recorded was 165 F degrees, which in race (and very hot weather) conditions is doable.
madness is offline   Reply With Quote
Old 04-15-2013, 10:04 PM   #189
hi,
If your pinion is in contact with the top deck, it's a problem of pinion width. I use GreenRC pinions, which are standard size one (like Xray, RW and many other brands), and it simply pass on the center of the upper deck, without problem.
Old 04-21-2013, 08:04 PM   #190
Hello
Team Magic 2mm
Kfactory 2.3mm
Kfactory 2.5mm
That's all
I have just found through luck that the XRay T3 top deck is a perfect match as long as you add a 0.5mm shim under where the screws mount to the bulkheads.
Old 04-22-2013, 08:26 PM   #191
twelvegauge's Avatar
Send a message via AIM to twelvegauge Send a message via MSN to twelvegauge
Is there a trick to installing the bone blades on the axles without breaking them?
Is there a better blade that fits from another manufacturer?
www.sycrcmaraceway.com
Maple Acres Raceway, SYC R/C Racing
I-Lap Timing System, R/C Scoring Pro
Replacement fans for esc's & heat sinks
[email protected] or 630-935-0132
twelvegauge is offline   Reply With Quote
Old 04-22-2013, 11:35 PM   #192
Hello
Yes, the material is extremely hard, so it's difficult to insert them.
Here is my method:
1. Insert the pin on the first hole
2. Heat the center of the blade with a lighter
3. Insert the pin on the second hole (with a long nose plier)
4. Heat the center of the blade to make it perfectly curved arround the ball
Old 04-23-2013, 04:04 AM   #193
Hello
Here is my method:
Thanks. That worked but sucks they made them so hard.
Old 04-23-2013, 04:06 AM   #194
What brand spur gear fits well? I have some old ones that fit but can't remember who made them.
Old 04-23-2013, 11:07 AM   #195
We asked for HARD blades due to high power modified motors... it's hard to insert the blade, but you will "never" destroy your aluminium outdrives due to a broken blade.
Xray blades will also fit.
Seattle RC Racers/Hangar 30 PutAwayWet Northwest Racers 18793 Today 06:01 PM
Electric Touring / On-Road RC Screaming Wind Manila Racers 32167 05-02-2017 11:20 PM
