Old 06-07-2012, 07:43 PM   #151
twelvegauge's Avatar
Send a message via AIM to twelvegauge Send a message via MSN to twelvegauge
Originally Posted by dshy View Post
I was talking with the owner of one of my local hobby shops on friday, he just got back from the reedy race down in california, and reported that the guys down there were using silicone earplugs in their front diff for the the equivalent of about 1,000,000 weight gear fluid. I haven't tried this yet, but I will most likely take the advice of many people and get the K factory front spool.
If anyone tries this, share how it works
I'm assuming they are using an equivalent to the link below.
http://www.walgreens.com/store/c/wal...003969-product
Before I bought the spool I used duct putty and it made a huge difference.
I like the spool much better. I got a more constant feel and it entered the corners better.
www.sycrcmaraceway.com
Maple Acres Raceway, SYC R/C Racing
I-Lap Timing System, R/C Scoring Pro
Replacement fans for esc's & heat sinks
[email protected] or 630-935-0132
twelvegauge is offline   Reply With Quote
Old 06-07-2012, 07:45 PM   #152
For those who have the stock CVD's I would upgrade to the Kfactory CVD's. I broke my front arm and the CVD bone end shattered on the outdrive side. I plan to upgrade ASAP.
Old 07-22-2012, 10:23 AM   #153
The car is setting up and running really nice. The CVD's held up for me all right, however i had an issue where cup got a little tweaked and refused to hold together the pin kept slipping out and binding itself up. I've installed the K-Factory one way with their beefed CVD's. There seems to be a little more chatter on power up front, overall a little less smooth than the stock bits, but its helped a lot out on the track, I shaved about a second off my lap times with the new front setup.
I switched out the rear diff with the old front to see how the stiffer diff would run, i felt it slowed me down a bit, the car seemed to have more bite on braking but wanted to track a little wider on turns than the looser old stock diff. I'll keep playing with it and let you guys know.
**UPDATE**
After adding a 1.5 shim to the front K-Factory A-Arm Holder the shaking caused by the Front Spool was eliminated. I added a little oil between the shims and retainers. If you choose to do this, remove your front suspension and flap the A-Arm to ensure that the arms can still move freely under their own weight.
There is now a 1.5 shim to the front and rear of each arm, what characteristics will change if i choose to move both shims to either front or rear vs splitting them? I would assume it will change the Front/Rear stance but how will this effect the car?
dshy is offline   Reply With Quote
Old 08-21-2012, 03:22 AM   #154
Team Magic E4RS II Race Results:
-Simon Allemann / Team Magic E4RS II is Swiss National Champion !
-Simon Allemann wins round 4 of Swiss Championship !
Team Magic E4RS II new parts:
507127H = New HARD material front arms
507132H = New HARD material rear arms
Link: http://blog.hrcdistribution.com/?p=636
Soft original arms are still available.
Team Magic E4RS II revised parts:
Latest batches of 507139 Steering blocks and 507142 are now HARD material
Team Magic E4RS II setups:
-Swiss Championship round 4 setup
More setups here.
RC Infos is offline   Reply With Quote
Old 08-28-2012, 02:46 PM   #155
Another title for Team Magic E4RS II !
Maxim Naegels wins Belgian Championship overall title !
http://blog.hrcdistribution.com/?p=747
Old 09-24-2012, 09:48 AM   #156
Hello everybody
New E4RS II tips here: http://blog.hrcdistribution.com/?page_id=171
E4RS II recently wins LRP Challenge in France and in Germany.
Old 10-03-2012, 01:57 AM   #157
Hello to all !!
Some new results and news:
-E4RS II on the podium at Lostallo for the last round of Swiss Championship
-Jordy Dubuis Junior Swiss Champion
-Setup for Lostallo
Old 10-22-2012, 02:12 AM   #158
devilfish's Avatar
Decided after much um'ing and ah'ing over all the different chassis's to get the E4RSII last night. Hoping it shows up late this week/early next, will report back when it's built .
devilfish is offline   Reply With Quote
Old 11-05-2012, 12:40 AM   #159
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
Alright. Decided im probably gonna get one of these to run at our speedweekend event this january.
Without spending a mint in upgrade parts, are there any parts i should pick up straight away?
really was shopping for a car i could just, build and race.. but seems impossible lol.
gonna be running it in 17.5 blinky on spec Jaco Blue's. I was working on my e4rs a little in the other thread but looking up part availability,, say... for a 3deg castor block even.. not so encouraging.
ill prob make a set of parts to see how it works in modified but move to this car.
probably send a lot of questions your way rcinfos =)
valk is offline   Reply With Quote
Old 11-05-2012, 03:41 AM   #160
Hello
Spool with steel oudrives would probably be the most important.
Old 11-07-2012, 08:58 PM   #161
valk's Avatar
Kfactory universals or tm option? Is the car so bad without these upgrades?
Old 11-07-2012, 11:07 PM   #162
You can run original universals, I'm running them on the rear end without any problem. On the front, I use Kfactory driveshafts with double articulation, as many drivers also do on many other brands and cars; it's not a problem of quality.
About spool, it's only because the kit is delivered with 2 gear diff. Personally, I usually use front spool, especially on carpet. If you choose to use spool, I recommend the steel outdrives instead of the aluminium, for a perfect durability.
Old 11-22-2012, 11:03 AM   #163
Hello to all
The E4RS II got one more time some great results !
The car is simply fantastic with the last setups.
TQ + Victory of Walter Pollet-Villard at the round 1 of SITCC @ Geneva:
1. Walter Pollet-Villard - Team Magic E4RS II / GreenRC / K Factory
2. Alexandre Laurent
3. Cham Dassanayake
4. Jean-Marc Betticher
5. Bastien DeMarco
6. Alexandre Amort
7. Vincent Cavard
8. Raffaele Tolotta
TQ + Victory of Patrick Gassauer at the LRP-HPI Challenge @ Solms:
1. Patrick Gassauer – Team Magic E4RS II / GreenRC / K Factory
2. Felix Wiessmann
3. Christian Mertke
4. Matthias Keding
5. Andreas Schuch
6. Max Mächler
7. Dai Sakaguchi
8. Frank Fuchs
9. Tim Walther
10. Daniel Anthes
Lap Record at 1st round of Swiss Indoor Championship:
9’551 Troyon Lionel – Team Magic E4RS II / GreenRC / K Factory
9’584 Asendorf Noah
9’603 Leonardi Simone
9’655 Streuli Markus
9’664 Nuno Santos
9’686 Stutz Beni
9’733 Bäumler Marc
9’787 Dubuis Jordy – Team Magic E4RS II / GreenRC / K Factory
9’864 Kupper Roland
9’955 Braunschweiler Daniel
New floating servo mount
Old 11-28-2012, 07:44 AM   #164
Hello
Here is a complete assembly review: http://www.rcinfos.com/2012/2012_11_...ic_e4rs_II.php
This is in french language, but there are more than 100 pictures that everybody could easily understand ^^
Old 12-18-2012, 05:20 AM   #165
Hello
Team Magic E4RS II remains unbeatable at SITCC series round 2 with TQ and Victory !
More details here
Seattle RC Racers/Hangar 30 PutAwayWet Northwest Racers 18803 Today 08:34 PM
Electric Touring / On-Road RC Screaming Wind Manila Racers 32167 05-02-2017 11:20 PM
