Old 12-15-2004, 09:29 PM   #121
cooliomojo-CEBU's Avatar
30 deg c is about the track temp here. im just concerned because after each run, the tires seem to be really warm. and im already using 40r tires. should i just return the tires or should i just run the tires?
cooliomojo-CEBU is offline   Reply With Quote
Old 12-15-2004, 09:46 PM   #122
lee82gx's Avatar
If you can, return them. In tropical weathers, 28R is way off. I'd expect them to last maybe under 5 runs. You'll get grip for sure, maybe even too much.
lee82gx is offline   Reply With Quote
Old 12-15-2004, 10:05 PM   #123
REALLY? oh no. i guess i have to return them! tsktsktsk!
Old 12-15-2004, 10:35 PM   #124
Trader Rating: 15 (100%+)
Default tire softeners
You guys might want to check out tire softeners ..for gokarts or race cars they seem to help but most tracks wont allow because of smell. just use it at home ..best to use is fast track.. but its expensive about 100$a gallon.
AARON YOUNG is offline   Reply With Quote
Old 12-16-2004, 08:28 AM   #125
Originally posted by cooliomojo-CEBU
I need help...... my friend gave me 28r sorex tires for xmas. unfortunately, most people here use 40r. i have been using 40r and 36r since. i do not know how this tire functions. i want tires that are durable and will last a long time. what should i do? please help me as i have a race tom and im planning to use new tires. im in the philippines. temps here are about 90degsF and the track where we race is made of cement.
Use 40R all the way in our track. This is what am using and showing good race result. If u can budget tire warmer, then buy it.
Nella-Nobrob is offline   Reply With Quote
Old 12-16-2004, 10:54 AM   #126
Shane Reinink's Avatar
R/C Tech Charter Subscriber
Trader Rating: 16 (100%+)
Send a message via AIM to Shane Reinink
Originally posted by duckman996
Does anyone know where I can get Pit Shumizu 24RR tires?
Thanks,
Not sure about Canada but here in the USA it is impossible to find Pits unless they are from stock bought last year as there is no longer a USA importer. I emailed Pit and asked them if they were going to be supplying the USA anytime soon. I was told that they ran out of necessary material to produce tires last year, and have finally received all material needed and have tires in stock again. Only problem is they still have no USA importer and the minimum order is pretty large. Hopefully someone will step up and get some ordered.
Shane Reinink is offline   Reply With Quote
Old 12-20-2004, 08:45 PM   #127
as nella suggested, im thinking about getting tirewarmers as soon as i have budget..... what tire warmers do you recommend...?
Old 12-21-2004, 01:18 AM   #128
It depends on ur budget. There are cheap one and acceptable to use. U can see Oscar and Jovy's tire warmer. What am buying is the one with temperature control. It's about USD 150. U can buy the ordinary at about PHP 1500-2500.
Old 12-21-2004, 01:35 AM   #129
there is php 1500 nga tire warmers? can you get one for me nella? i think tire warmers are a must especially if the tracks are a bit cold......ive just visited the f1 website and was reminded of its importance.
Old 12-21-2004, 02:31 AM   #130
lee82gx's Avatar
RC tyre warming is different from F1.
Our shods need about only 1/2 a lap to get warmed up, from 30 off the track to 36-40 on the track surface.
F1 tyres need a lot more temperatures.
But having a tyre warmer is indeed a convenience, no need to make a hot lap.
Old 12-21-2004, 03:39 AM   #131
Order it thru Medy...
Old 01-24-2005, 08:28 AM   #132
Trader Rating: 37 (100%+)
speaking of tire warmers...
i noticed in pics that some pro drivers have been putting paper towels or something around the tire then put the tire warmer over it...
what's the reasoning behind that...is it to distribute the heat evenly and not creat hotspots on the tire?
like this pro4 pic...
http://home.comcast.net/~anthony.isl...4/worlds_3.jpg
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 01-24-2005, 08:46 AM   #133
Eirik's Avatar
I think it's because the Much-More warmers etc. are made for Sorex tires so when you use Take-Off's the Alu cup will not sit properly around the tires....
Eirik is offline   Reply With Quote
Old 01-24-2005, 02:24 PM   #134
kidDynomite's Avatar
I normally run foams, but my buddy runs rubbers and had a brand new set put onto a set of cheep OFNA rims (8 for $8). I warned him that they would shatter. But anyways, he managed to break the center out of one of the dishes. So the Q: is, can he soak the tires in acetone to recover the tire(s) (Sorex) or will the acetone hurt the rubber?
kidDynomite is offline   Reply With Quote
Old 01-24-2005, 02:29 PM   #135
tommy.
i would think the acetone would be bad...but i'm not sure. some people say they boil the tires to get the rubber off the rim. that might be a better way.
_________________
another question:
what are people running for droop with rubber tires on carpet....just looking for input i know there are tons of variables.
if you respond please let me know what you are running for droop in 'mm' over ride height....not the number on those "droop gauges"
thanks
Touring Car Rubber Tire Lot $100 barnacle R/C Items: For Sale/Trade 14 10-01-2007 10:48 AM
Best touring car for rubber tire on carpet racing? rccars4scott Electric On-Road 0 09-18-2006 04:55 PM
Wisconsin Rubber Tire Touring car Racers ottoman Wisconsin & Illinois Racing 19 05-03-2006 07:34 PM
Stickum Tire Traction for Touring Car Rubber Tires noline R/C Items: Wanted to Buy 0 06-18-2005 01:08 PM
Touring Rubber Tire Blow Out !!!! gpd123 R/C Items: For Sale/Trade 3 07-26-2004 07:52 PM
