Old 12-11-2004, 03:21 AM   #106
Funny thing, everybody's says baddly about Take-off, and sometimes I have a bad time with them ...
Kyosho has 6 different tires, wich type are you using? The G's or the regular ones? And with what insert?
gearless is offline   Reply With Quote
Old 12-11-2004, 11:11 AM   #107
Send a message via AIM to A-Ko
I have liked Take-offs for outdoor. Never had luck with them indoor, then again I never owned a premount set.
Jeffrey
teamgravityrc.com - motivrc.com
USVTA National Points Member #101
A-Ko is offline   Reply With Quote
Old 12-12-2004, 04:56 AM   #108
Yes there are a lot of different kyosho tires I'm not sure how many there are for racing but there are dozens of them. I have never used the indoor tires but the ones I use are very good.
They are the 92014's
frozenpod is offline   Reply With Quote
Old 12-12-2004, 07:15 PM   #109
Does anyone know where I can get Pit Shumizu 24RR tires?
Thanks,
duckman996 is offline   Reply With Quote
Old 12-12-2004, 08:18 PM   #110
tc3jp is offline   Reply With Quote
Old 12-12-2004, 08:23 PM   #111
The insert varies depending on the track and the conditions.
I have about 30 or so different inserts but these are what I useually use sorex MB, MC and the kyosho foam insert depends on the day and the track.
I would really like to try a soft insert in the same profiles of the MB and MC does any one know if sorex make a Soft B and Soft C
Old 12-12-2004, 08:48 PM   #112
AdR|aN's Avatar
Send a message via ICQ to AdR|aN
From what i know and what i see, i don think sorex does make Soft B nor Soft C.
Usually i will run Medium B for practice/bashing and Medium C for race.
I think the difference between B n C inserts are the thickness. C would have more airgap hence is thinner compared to B. I did tried Speed Mind soft (yellow) inserts but the airgap is almost the same with B or A.
AdR|aN is offline   Reply With Quote
Old 12-12-2004, 09:10 PM   #113
yeah i know what the difference is
I would like to try something in the same profile that is slightly softer that is all maybe help generate more grip
Old 12-12-2004, 11:44 PM   #114
Trader Rating: 15 (100%+)
Default pit tires
I know most people dont use pits cause they are hard to find but they just released them again.i have almost 100 runs on a set. and they just wore through to the belt on the fronts.we are only allowed to use tq orange.. tires only seem to get faster as they wear down. I scuff them on a truer or they glaze over .. tire stays dull till its gone. the best combo seems to be 27/24 for stock and 30/27 for mod. no air gap seems to help the tires .most of the wheel gets bent before the tires performance falls off.
AARON YOUNG is offline   Reply With Quote
Old 12-13-2004, 03:09 AM   #115
cooliomojo-CEBU's Avatar
hey, IS CA any good for gluing tires?
cooliomojo-CEBU is offline   Reply With Quote
Old 12-13-2004, 03:18 AM   #116
lee82gx's Avatar
yes, i have only ever used CA.
what else is there to glue tyres with?
lee82gx is offline   Reply With Quote
Old 12-13-2004, 03:05 PM   #117
Gotta say that the pits always worked very very well they had a great tolerance to different condition and provided more grip then take off once they had done a fair few runs
Old 12-15-2004, 02:57 PM   #118
tuil21's Avatar
hey guys, can i get your alls input on some tires for some street tires for tempatures between 30F to 40F degrees outside would traction compound help me outside on the street?
tuil21 is offline   Reply With Quote
Old 12-15-2004, 08:23 PM   #119
I need help...... my friend gave me 28r sorex tires for xmas. unfortunately, most people here use 40r. i have been using 40r and 36r since. i do not know how this tire functions. i want tires that are durable and will last a long time. what should i do? please help me as i have a race tom and im planning to use new tires. im in the philippines. temps here are about 90degsF and the track where we race is made of cement.
Old 12-15-2004, 09:16 PM   #120
well you can check the temp rating of the 28's which I think is about 30deg C of the track if the track is higher then they will go off
Touring Car Rubber Tire Lot $100 barnacle R/C Items: For Sale/Trade 14 10-01-2007 10:48 AM
Best touring car for rubber tire on carpet racing? rccars4scott Electric On-Road 0 09-18-2006 04:55 PM
Wisconsin Rubber Tire Touring car Racers ottoman Wisconsin & Illinois Racing 19 05-03-2006 07:34 PM
Stickum Tire Traction for Touring Car Rubber Tires noline R/C Items: Wanted to Buy 0 06-18-2005 01:08 PM
Touring Rubber Tire Blow Out !!!! gpd123 R/C Items: For Sale/Trade 3 07-26-2004 07:52 PM
