Old 01-24-2005, 02:34 PM   #136
kidDynomite's Avatar
Thanks, Tony! I'll let Mark know to hard boil his wheels.
As far as droop goes, I usually start with 2mm front and back over ride height. I then usually mess with the fronts and bring them to about 1.5mm. Works good at both RSJ and AJs. The only thing I change between the two tracks are spring combos.
kidDynomite is offline   Reply With Quote
Old 01-24-2005, 02:37 PM   #137
rdub202's Avatar
Trader Rating: 19 (100%+)
Send a message via AIM to rdub202
does anyone really run rubber on carpet?
_|Team Academy GV2 Pro_|_Team Academy SBV2 Pro|_--->Losi xxxbK2 (FOR SALE)
_|Factory Tracks Midwest Series_|_www.factorytracks.com|_
_|Team Upgrade-RCid_|_www.upgrade-rc.com|_
_|MRC/Team Academy_|_www.modelrec.com|_
rdub202 is offline   Reply With Quote
Old 01-24-2005, 03:33 PM   #138
MartinSorlie's Avatar
Approximately the whole world, it's only in the US you run those silly foams...
Martin Sørlie, 1985, R/C since 1995.
TLR - Spektrum
www.teamsmallsize.com
MartinSorlie is offline   Reply With Quote
Old 01-24-2005, 03:35 PM   #139
Eirik's Avatar
@rdub202,
In Europe there is no Foam racing at all, only rubber!! So the answer to your question is, yes!
@Nexus,
I always run 3.5mm up front and 5.0mm in the rear.... if traction is really low I will run 4.0mm in the back.
This is an adjustment that will change the feel of the car, but it will not affect the laptimes too much.....
Eirik is offline   Reply With Quote
Old 01-24-2005, 06:16 PM   #140
lee82gx's Avatar
i've tried all sorts of boiling and oven heating but i can't seem to really be able to separate the rubber nicely.
lee82gx is offline   Reply With Quote
Old 01-24-2005, 07:12 PM   #141
aceton is the only way to go put them in over night and the rubber just peels of easier then putting them on.
sometimes they need to site untill lunch time the next day but they allways come off
I use a icecream container with a air tight lid
frozenpod is offline   Reply With Quote
Old 01-24-2005, 07:24 PM   #142
rdub202's Avatar
okay well what rubbers do you crazy non-americans run on carpet?
Old 01-24-2005, 07:29 PM   #143
OVA
OVA's Avatar
Trader Rating: 79 (100%+)
Well not just the usa..The Canadian also run foam tires for carpet race
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 01-24-2005, 07:32 PM   #144
OVA
OVA's Avatar
Originally posted by kidDynomite
I normally run foams, but my buddy runs rubbers and had a brand new set put onto a set of cheep OFNA rims (8 for $8). I warned him that they would shatter. But anyways, he managed to break the center out of one of the dishes. So the Q: is, can he soak the tires in acetone to recover the tire(s) (Sorex) or will the acetone hurt the rubber?
yes I believe that the acetone will dried up the rubber
Old 01-24-2005, 10:28 PM   #145
Eirik's Avatar
rdub202,
I want to apologize for my countryman who thinks foams is silly, racing is fun wether it's on foams or rubber!
At the latest big races in Europe we have been using Take-Off 22's and 27's as a control tire with JB/Orion inserts.
I have been testing allot and Sorex tires works better, lasts longer and gives me the fastest laptimes, still using the JB inserts.
Sorex 32 seems to be the best overall tire, very consistent for many runs!!
Cheers mister!
Old 01-24-2005, 10:42 PM   #146
Very true, I wouldn't stop racing if it was foams... There was a very humoristic undertone there
TLR - Spektrum
Old 01-25-2005, 06:56 AM   #147
rdub202's Avatar
no need to apologize, i didnt take offense at all. im going to have to get a set of each and compare the two (rubber v. foam)
thanks erik
Old 01-25-2005, 07:00 AM   #148
Trader Rating: 37 (100%+)
Originally posted by Eirik
rdub202,
Cheers mister!
Eirik.
Which JB inserts have you been using with CS22s/27s.
Around here the HPI Red is really popular...just looking for options.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 01-25-2005, 05:09 PM   #149
Both me and Eirik have been using thin mostly. Can't get enough airgap with anything else, as the CS's are very low profile.
/Martin
TLR - Spektrum
Old 01-26-2005, 08:08 AM   #150
Originally posted by Nexus
tommy.
i would think the acetone would be bad...but i'm not sure. some people say they boil the tires to get the rubber off the rim. that might be a better way.
OVA, thanks for your input. He is ruling acetone out of the question.
NEXUS, Mark said he was boiling the wheels last nite for over 45min, but they hardly came loose. I fell asleep and forgot to check on his progress.
Touring Car Rubber Tire Lot $100 barnacle R/C Items: For Sale/Trade 14 10-01-2007 10:48 AM
Best touring car for rubber tire on carpet racing? rccars4scott Electric On-Road 0 09-18-2006 04:55 PM
Wisconsin Rubber Tire Touring car Racers ottoman Wisconsin & Illinois Racing 19 05-03-2006 07:34 PM
Stickum Tire Traction for Touring Car Rubber Tires noline R/C Items: Wanted to Buy 0 06-18-2005 01:08 PM
Touring Rubber Tire Blow Out !!!! gpd123 R/C Items: For Sale/Trade 3 07-26-2004 07:52 PM
