Old 12-06-2004, 08:08 AM   #31
koabich's Avatar
Send a message via Yahoo to koabich
Originally posted by crimson eagle
Lee,
Pulse Charging, also known as burp charging has a very small dishcarge pulse every second. The theory is that it helps to break down the crystaline structure which forma in the cell over time. I read an interesting Nasa study about it a while ago. They found that it really helped to extend the lifecycle of the cell. I'd like to do extended cycles for things like this but I don't have a charger to dedicate to it for 6 months and I certainly don't have the cells to throw away.
Chris.
I thought this wasn't supposed to be good for Nimh cells? Has anyone done this on their 3000 or 3300's?
koabich is offline   Reply With Quote
Old 12-06-2004, 09:42 AM   #32
lee82gx's Avatar
I think it's also known as flex charging, and as far as i remember none of my chargers recommend that for NiMh..
Is it recommended in your Pro-Trak?
lee82gx is offline   Reply With Quote
Old 12-06-2004, 11:01 AM   #33
crimson eagle's Avatar
Send a message via ICQ to crimson eagle
lee,
It's more of a personal preference thing, if it works for you go for it. It's available with Pro Trak, whichever you use is up to you. I did not get good result with it comparing end data. I had better results with Hard pulse and Multi Phasic Charging. I do still use linear when racing though, I want some more good results to come in before I start using different charge methods.
crimson eagle is offline   Reply With Quote
Old 12-06-2004, 01:27 PM   #34
adamkerrnz's Avatar
yo, i payed $29 for a 6 cell matched sport pack from hypercells. i ordered 3 of them, shipping was around $20 i think.
adamkerrnz is offline   Reply With Quote
Old 12-06-2004, 02:20 PM   #35
fatbear's Avatar
Send a message via Yahoo to fatbear
Adam, you should have talked to me dude. I am sposored by SURGE and I would have recommended the best cells for you to get from SURGE.
Oh well never mind.
Team Associated www.teamassociated.com
Team Tekin www.teamtekin.com
B-Fast R/C Performance www.bfastrc.com
JConcepts www.jconcepts.net
Ace Hobby Distributors www.acehobbyaustralia.com
fatbear is offline   Reply With Quote
Old 12-06-2004, 02:45 PM   #36
burbs's Avatar
Send a message via AIM to burbs Send a message via Yahoo to burbs
If you cycle a pack on a turbo 30 with pulse or flex charge, the numbers will go way up.. but the pack will run flatter then a prctice pack... a true linear charge is and always seems to be best... ive tried both.. and with the flex i was almost a full lap off the pace... these are just my findings, but i know others who have tried it with the same results... ill take mad rip over life cycle of a pack...
burbs is offline   Reply With Quote
Old 12-06-2004, 03:15 PM   #37
Burbs,
I agree, I do not get good results from repulse charging, much better by the numbers is hard pulse or multi Phase charging though I have not tried it on the track. I'd guess that the turbo thirty does not take into account the discharge spike when calculating the Mah.
One thing I do though. If I'm charged way early before my race (say more than 20 minutes) before peaking I set a discharge for 20 or 30 seconds first, really wakes up the cells as compared to just a straight repeak. I have found that repeaked cells can feel flat sometimes. This does help.
Chris.
