Old 12-03-2004, 08:26 PM   #1
vi3tishduy's Avatar
Send a message via AIM to vi3tishduy
Default ESC Problem, Help please!
Hey guys, I got my Promatch Batteries today, 1.18's and i charge em, and plug em up..
next thing i know I press the throttle full for aorund 15 seconds and the car shuts off. Nothing is hot, I let the batt rest to cool off, then I plugged in with the esc. Esc was cool too. The esc I am running is the LRP F1 Pro Reverse which was 120 or so. There were no sparks, the car just died out. And I know I didnt short the batt because it didnt touch any aluminum, and the batt still has a full pack left. I can unplugg the esc with the batt and plugg in again and do the same thing, then it shuts off, any ideas guys?
vi3tishduy is offline   Reply With Quote
Old 12-03-2004, 08:28 PM   #2
Post
Try resetting your speedo .. sometimes they will get a jolt of power and loose there settings in memory....
Mark Barden .
mb racer is offline   Reply With Quote
Old 12-03-2004, 09:00 PM   #3
Send a message via AIM to greencactus3
are you sure you didnt plug the battery in the wrong polarites?
greencactus3 is offline   Reply With Quote
Old 12-03-2004, 09:03 PM   #4
jackfast's Avatar
I am willing to bet its a case of reverse polarity.
jackfast is offline   Reply With Quote
Old 12-04-2004, 02:27 AM   #5
pink pac man's Avatar
have u tryed a diferent car/motor/batteries
take the motor out .......is the motor jamed
pull the belt/spin the prop shaft........does it spin at all
use a different batterie......have u recieved a dead cell
pink pac man is offline   Reply With Quote
Old 12-04-2004, 03:44 AM   #6
It is most likley a motor or esc prob. Cheak your motor for a hung brush or rocks... then try reprograming your speedo...
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 12-04-2004, 07:24 AM   #7
vi3tishduy's Avatar
Ok, the batts I got are not dead, still fully charged, I tried my stick pack from SMC did the same thing, the esc never shut off for 1 whole minute, both batteries were fully charged. The SMC is a stick pack while the Promatch arnt. Promatch assembled the pack for me with deans so, IDK what reverse polarity is, everything is moving fine, nothing jammed, motor is spinning, tires everthing, I just don't know. But one thin I noticed is that when the ESC shut off with the ProMatch Batts, it started to make a sound, and the the pitch became louder and louder, i'm not sure if it was the ESC or the Reciever, cause I have a crappy Radio/Reciever... Thanks for post.. I dont wanna buy a new esc,.....
Old 12-04-2004, 07:32 AM   #8
raving-monkey's Avatar
Send a message via MSN to raving-monkey
have you got a sticky brush?
just tug at the brush shunt a few times to make sure the brush can move freely in the brush hood.
does your motor have a shottky on it? if so is the on the right way round?
raving-monkey is offline   Reply With Quote
Old 12-04-2004, 07:45 AM   #9
vi3tishduy's Avatar
I dont think it has a shokty thingy, only wires touching it is the ESC, brushes are free
Old 12-04-2004, 09:44 AM   #10
jackfast's Avatar
Take out your speedcontrol does it smell burnt? Open up the case if you can and take a look and see if anything has the tell tale signs of a short....i.e. brown orange color on the plastic compenents. You may have blown a fuse. Sometimes the speedo will work but only barely. It will run at half power, or in my case full power. Speed controls are very delicate. My quantum competition two has had many problems with shorts and etc. Make sure you don't ever cut off your switch. That is what I was doing, and it turned out to be a bad idea.
Oh! Take a look at the circuitboard where you solder your powerwires onto. It may have shorted out across the board.
Old 12-04-2004, 09:58 AM   #11
Try changing crystals, do you still have steering?
pops is offline   Reply With Quote
Old 12-04-2004, 09:58 AM   #12
vi3tishduy's Avatar
No sparks flew, dosnt smell burnt or anything. Everything looks a.o.k to me. Maybe its just that this LRP esc was crap. I wasted my money... Sigh... Now I gotta get a new one if I wanna run these new Promatchs I got..
Old 12-04-2004, 10:00 AM   #13
vi3tishduy's Avatar
another...
Old 12-04-2004, 10:02 AM   #14
vi3tishduy's Avatar
nother one
Old 12-04-2004, 10:04 AM   #15
vi3tishduy's Avatar
Both batts..
ESC PROBLEM ghj1997 Electric Off-Road 13 06-04-2008 08:38 AM
Problem RaceANissan616 Nitro On-Road 20 07-23-2006 09:07 PM
KO PRO PO VSF-1 PROBLEM mazmo Australian Racing 4 07-24-2005 07:38 AM
New to R/C and I have a bit of a problem ZeeBMaN Rookie Zone 6 05-15-2003 05:08 AM
