Old 12-02-2004, 11:31 PM   #1
JayBee's Avatar
Trader Rating: 31 (100%+)
Post Integy's NEW top of the line charger
It's called the 16X-G40...
Has anyone heard anything else exciting about this new charger?
It sort of looks like the Futaba CDR-5000 with the silver case and large backlit screen. It also has multiple charging profiles and a 40A discharge; one thing that it has that the Futaba doesn't is MOTOR RUN , yeah baby!
looks and sounds interesting...
- jaybee
(source material: Jan. issue of Xtreme RC mag, pg.218)
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 12-03-2004, 01:08 AM   #2
Send a message via AIM to micros_rock
Default ...and more...
Integy has two new chargers coming.
INDI 16X-G40 Computerized Battery & Motor Management
Designed for serious racers, high resolution backlit graphics display, display each cell information individually, perfect for Ni-Cd, Ni-MH & Li-lon, change 0.1A to 12A (1 to 8 cells), 3 phase charging with programable rates, temperature probe, selectable temperature cut off, 1mV to 20mV / cell selectable cutoff, extremely accurate unit calibration, discharge up to 40A (0.9V/cell), run motor up to 13A (0.1 to 9.0V), break-in motor with programable timers, test motor rpm and current draw, AC/DC operation, accurate remote voltage sensing wiring, built-in quadruple cooling fan, 1 year limited warranty, available in MAY 2005
INDI 16X8v6 Computerized Battery & Motor Management
Designed for serious racers, perfect for both Ni-Cd & Ni-MH, change 0.1A to 6.5A (1 to 8 cells), 3 phase charging with programable rates, temperature probe, selectable temperature cut off, 1mV to 20mV / cell selectable cutoff, extremely accurate unit calibration, discharge up to 30A (0.9V/cell), run motor up to 13A (0.1 to 9.0V), break-in motor with programable timers, test motor rpm and current draw, AC/DC operation, accurate remote voltage sensing wiring, built-in twin cooling fan, 1 year limited warranty, available in JAN 2005
micros_rock is offline   Reply With Quote
Old 12-03-2004, 01:23 AM   #3
Entropy's Avatar
OMG, Is this a charger to end all chargers.
All we need is a computerized cup holder with temp monitoring to keep your drinks cool at the pits.
Entropy is offline   Reply With Quote
Old 12-03-2004, 01:44 AM   #4
Team Duratrax's Avatar
Send a message via MSN to Team Duratrax
I think both of those chargers are absolutly ridiculous! you really dont need any of the bullcrap features on these new high tech chargers,shit your just charging a battery for crise sake!
Team Duratrax is offline   Reply With Quote
Old 12-03-2004, 06:14 AM   #5
ALBERTO's Avatar
Trader Rating: 23 (96%+)
Send a message via AIM to ALBERTO Send a message via Yahoo to ALBERTO
FOR THE AVERAGE PERSON YA RIGHT. But for those who strive to fly on the track it is essential to have a lot of these things.
still fishing
ALBERTO is offline   Reply With Quote
Old 12-03-2004, 06:47 AM   #6
picco007's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to picco007 Send a message via Yahoo to picco007
Does anyone know about the discharger that the first picture shows? I heard it was a 30 amp individual cell discharger that goes down to .0v. Can someone confirm?
EA Motorsports
picco007 is offline   Reply With Quote
Old 12-03-2004, 07:16 AM   #7
JayBee's Avatar
Post
I'll definitely check into that; for sure I'm holding out for one of these babies ...
- jaybee
Old 12-03-2004, 09:03 AM   #8
R/C Tech Charter Subscriber
That first one is sweet. Does everything the CDR5000 and the GFX does plus you don't need a freekin power suply. Very compact. I think I might hold out on buying a GFX just yet.
NismoSkyline17 is offline   Reply With Quote
Old 12-03-2004, 09:08 AM   #9
Just checked Integy's website. First charger retails at $399.99 and the second one retails at $259.99. Finally Integy finds a way to discharge over 20amps. About time.
Old 12-03-2004, 09:16 AM   #10
The only downside is you cant break in motors over 13 amps. Hard to set amp draw on 7t motors without a GFX.
IndyPhil is offline   Reply With Quote
Old 12-03-2004, 09:22 AM   #11
Matt Howard's Avatar
why do you need to break in a 7 turn? you pull the throttle once and the brushes are seated
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 12-03-2004, 09:23 AM   #12
Old 12-03-2004, 11:53 AM   #13
Super Moderator
Trader Rating: 17 (100%+)
For you guys who think you dont need a power supply, Every Integy charger Ive owned that is AC/DC does not work as well without the power supply. The power supply thats in the charger just cant compete with a rivergate 30 amp. Usually I find that the charger will over heat when you start doing some heavy discharging. I still use mine but i just hook it up to my powersupply. I aslo noticed that my charger (16x7) doesnt charge packs that have been dead shorted until you put some juice in them. Just points to consider.
Tekno|JConcepts|TeamTrinity|BOOMrc
Bob Barry is offline   Reply With Quote
Old 12-03-2004, 11:56 AM   #14
Hebiki's Avatar
Trader Rating: 26 (100%+)
1. 30 amp discharge - Yes
2. 0.00v cutoff - Yes
The INDI 030 discharge board is designed for stock and 19T racing, 30A discharge rate. It is the most advanced discharge / equalizing tray designed for high performance r/c car racing. The unit works on all high power Ni-Cd and Ni-MH sub-C size battery cells. This is a 0.0V cutoff discharge board, the unit deep discharge each cell and significant benefits include charge capacity increase, discharge capacity increase, actually runtime increase, average discharge voltage increase, reduced peak voltage and reduced internal resistance. This type of discharger can discharge each cell individually and there is no chance for cell reversal damage to occur. The basic operation of the 030 is pretty simple and straight forward. Easy t ouse clamp type switch with 3 pins connector on each terminal, built-in twin cooling fan, requires 12VDC input. The unit is bipolar, meaning that you can install your battery without worrying about the polarity. The 030 draws 30A rate from each cell individually.
more info here:
http://integy.automated-shops.com/cg...15104508402.ca
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 12-03-2004, 12:15 PM   #15
Korey Harbke's Avatar
oooooooooooo super coolness
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Pro-line Holeshot MTR's on pro-line 17mm 1/2" offset velocity dish wheels. AaronPrewitt R/C Items: For Sale/Trade 3 07-25-2007 12:45 PM
WTB: Novak Millennium Pro charger or a charger on the same line. xxx-ntad2 racer R/C Items: Wanted to Buy 5 12-21-2006 01:19 PM
Pro Line 40 Series Bowties Pro Line Weld Cammando Beadlocks F/S Rpp Hobby R/C Items: For Sale/Trade 0 04-23-2006 08:56 PM
Integy's "Down Travel Gauge" jeb4 Nitro On-Road 2 05-13-2005 07:38 PM
Top of the line charger wanted JohnA R/C Items: Wanted to Buy 6 06-22-2002 09:15 AM
