Old 11-02-2011, 08:56 PM   #1
TChan's Avatar
Send a message via Skype™ to TChan
Default Exotec F104
What does the exotec f104 come with? does it come with aluminum hop up parts or is it just springs and chassis? How much?
TChan is offline   Reply With Quote
Old 11-02-2011, 09:18 PM   #2
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
http://www.exotekracing.com/exo104-p...-race-chassis/
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 11-03-2011, 04:44 AM   #3
TChan's Avatar
[QUOTE=VooDooPH;9862048[/QUOTE]
Im kinda confused the picture doesnt show the aluminum motor mount and it doesnt say it has it in the description but in the picture of the full car it has a aluminum parts.
Old 11-03-2011, 04:55 AM   #4
VooDooPH's Avatar
motor mount not included... its basically a hopup set... you'd still need an F104 to complete the car...
High performance, lightweight chassis conversion that gives the F104 the competitive edge thanks to the improved chassis work and floating rear pod born from world championship rear pod suspension components.
-Using actual components from the World Champion Yokomo 1/12th we have re-engineered the rear pod into a 5 link floating rear pod for superior rear traction and stability.
-Includes a VCS through shaft center oil shock to perform tweak free side dampening.
-Carbon fiber 1 piece top deck to reduce tweak and allows just enough flex to maintain proper traction.
-Secure battery mounting system also accepts bullet plug type batteries.
-100% American made quasi weave 2.3mm thick carbon fiber components.
-Narrow chassis to reduce chassis scrub for better handling and more corner speeds yet plenty of room to mount electronics.
-Pan car type tweak screw and side spring adjustment feature to properly balance the rear pod and provide super smooth suspension action.
-Includes blue anodized battery posts, spacers and necessary alloy steel hardware.
-Maintains the stock wheelbase.
-Uses the stock F104 bodies (some trimming required).
Old 11-03-2011, 08:29 AM   #5
LMRacing's Avatar
Trader Rating: 27 (100%+)
Exotek just makes upgraded chassis for current cars. They dont sell any complete kits that I'm aware of.
LMRacing is offline   Reply With Quote
Old 11-03-2011, 09:57 AM   #6
MikeR's Avatar
Trader Rating: 15 (100%+)
Hi,
The pictures shows what's in the conversion. Also attached here. By the way, the EXO104 conversion is discontinued. The new F1R conversion will be replacing it this Friday.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 11-03-2011, 10:40 AM   #7
JamesHealey's Avatar
Mike what are the benefits of the f1r?
I have the exo104 on a wide 104. And it's great!
Just wondering what's the idea behind the new version what were you trying to achieve
JamesHealey is offline   Reply With Quote
Old 11-03-2011, 10:53 AM   #8
MikeR's Avatar
Hi James!
Forgive me as I post and copy from the F1R page because it explains in detail what your are wondering
In development since early 2011 to bring you the best Tamiya chassis option for the rapidly emerging F1 class.
Race proven features include;
- Link type rear pod for exceptional rear grip. The rear suspension pod includes ball links and reinforced easy set side links.
- Optimized battery and electronics location. The battery, esc and receiver are mounted as far back as possible to maximize the rear weight bias for improved rear traction and stability under acceleration and braking.
- New bottom plate only design helps generate more steering response. This coupled with the increased rear traction creates an overall better handling car.
- New alloy shock mount. This weighted design not only looks great but it serves a vital function as well. The weight of this part creates more rear weight bias for more on power grip and creates body roll so that it also creates more cornering/ lateral grip. On top of this it provides secure battery mounting and much easier battery removal by simply loosening the 2 mounting screws. The battery can then be lifted straight up and out without interference from the ESC or receiver.
- New design will accept standard 7.4v lipos or the new breed of lightweight 'shorty' 7.4v lipos!
- Includes black anodised rear pod pass-thru dampener and new mounting set.
- Includes Associated side pod springs and mounts. These are used to tune for steering response and pod level (tweak).
- US made premium 3.0mm quasi weave carbon fiber is used throughout.
- Rear chassis channel lets you cleanly route the ESC receiver plug directly under the battery to the receiver.
- Includes carbon servo brace for the F104.
- Compatible with any Tamiya F104 or F103 kit.
New pics are posted as well here; http://www.exotekracing.com/f1r-conversion/
Old 11-03-2011, 12:12 PM   #9
yourstruly22's Avatar
Originally Posted by MikeR View Post
Hi James!
looks awesome Mike. I especially like the way the servo is mount.
Pass me clean or don't pass at all
yourstruly22 is offline   Reply With Quote
Old 11-03-2011, 01:07 PM   #10
Where do the esc and receiver go with a full sized lipo?
Old 11-03-2011, 01:13 PM   #11
MikeR's Avatar
For more mechanical grip on each side of the battery much more towards the rear.
Thanks Sir!
Old 11-03-2011, 06:04 PM   #12
@MikeR
Is there going to be an R conversion for those of us that have the original Exo or are the 2 too different for it to be possible?
Sydewynder is offline   Reply With Quote
Old 11-03-2011, 06:07 PM   #13
My ESC struggled to fit on the Exo104, it looks like it wouldn't stand a chance on the F1R..
Have you made more room for it at the rear by widening the back end near the pod links?
Sorry for all the questions dude, Just weighing up the cost of upgrading to the F1R version, it looks cool but I'm killing it with the EXO104 Wide at the moment at my local track, I don't struggle for rear traction.. but then again i'm essentially running a 103 wheelbase which helps a lot with traction anyway.
Any idea when DMS-Racing in the UK will get the F1R upgrade?
Old 11-03-2011, 06:09 PM   #14
Sydewinder,
MikeR said on the HPI F10 thread that they would be doing an upgrade version, so hopefully that's confirmation.
Old 11-03-2011, 07:00 PM   #15
MikeR's Avatar
Originally Posted by Sydewynder View Post
@MikeR
James is correct- there will be an upgrade kit for current EXO owners. It will be available later next week.
No problem
The links are indeed set wider so there will be plenty of room for the esc and receiver. The EXO104 was pretty aggressive. The F1R will have a wider set up window for more consistent lap times. It is much improved for rubber tires on lower grip tracks.
DMS has them on reserve and they will likely be shipped to the UK on Monday.
Tamiya F104 Pro! NT Electric On-Road 9387 10-18-2017 03:12 PM
Horsham RC Carpet Racing 2010-11 Al Sodano Racing Forum 2116 09-26-2011 05:28 AM
Paposwing's F1 nation discussions PAPOSWING Racing Forum 727 08-09-2011 06:24 PM
