Old 06-06-2002, 12:03 AM   #1
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
Arrow some battery tech
i know everything in the world has been posted on this subject, but i'd just like a few questions answered.
i've been logging all the charge info from my mil pro with every charge. i've also graphed voltage vs. time curves during discharge on a lightbulb assembly. i know that the resistance willl change with temperature, but keeping most things constant, here's what i've noticed:
- the batteries that peak at high voltage when charging seem to run at a low average voltage. these same batteries seem to get hotter upon discharge.
is this a direct result of a high ir? resistance yields heat?
without being able to measure ir, i'm trying to make some generalizations so that i can determine the worth of my batteries on the bench using equipment i already own.
help!
seaball is offline   Reply With Quote
Old 06-06-2002, 01:48 AM   #2
Trips's Avatar
Trader Rating: 16 (100%+)
Yes, higher internal resistance will result in a higher peak voltage, and lower average voltage and more heat during the discharge.
Trips
MARSHAL!!
Trips is offline   Reply With Quote
Old 06-06-2002, 02:09 AM   #3
seaball's Avatar
thanks trips, you're the man. anything else that is useful to know about this stuff?
how about doing soldering work when the batteries are fully charged? will the iron heat the cell faster if it is charged?
Old 06-06-2002, 04:03 PM   #4
Super Moderator
Grizzbob's Avatar
No, not really, though if the cells' temperature is up anyway(as normally happens when a pack has peaked) it might seem like it heats up faster, but not by much......
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 06-06-2002, 05:06 PM   #5
Soldering charged batteries also makes it more likely to short out something and cause some real damage. If they are discharged and you short them there usually isn't any damage done if the short if removed relatively soon.
patcollins is offline   Reply With Quote
Old 06-07-2002, 12:24 AM   #6
seaball's Avatar
thanks fellas.
To tech or not to tech, Thats is the question David Butts Electric On-Road 15 12-19-2007 12:17 AM
Hakko 936, Spintec battery manager, Ko Ex-10, Spektrum Pro, tekin battery doctor Breeze R/C Items: For Sale/Trade 2 12-08-2007 09:47 PM
Everything about battery tech? Capone_GR Electric On-Road 10 02-03-2005 05:02 AM
10 6 cell battery packs, 3 stock motors and 2 sakio battery cases $52.00 ??? bigoTC3fan R/C Items: For Sale/Trade 1 09-22-2004 06:07 PM
Battery Tech Help fastfred Electric On-Road 10 11-02-2003 02:36 AM
