Old 10-31-2011, 12:35 PM   #1
Default What 17.5 motor to buy
I know this will bring much debate but i have been out of 12 scale for a while and i am getting back in and need a new motor. We run 17.5 with turbo and boost. I am looking at some trinity motors but not sure what to get any help would be good.
cheifman is offline   Reply With Quote
Old 10-31-2011, 03:40 PM   #2
SNIPR's Avatar
Trinity D3 was always a great motor for me in 1/12
thevinylgarage.com - facebook.com/TheVinylGarage - facebook.com/THETrack806
Not Sponsored by:
Viper | Tekin | Trinity | Serpent | Durango | Gravity RC | Pro-Line | Radiopost
SNIPR is offline   Reply With Quote
Old 10-31-2011, 03:57 PM   #3
ReVtech! It's a D3 with more timing!
TRC-ReVtech-Epic-Trinity
Cowarn is offline   Reply With Quote
Old 10-31-2011, 04:04 PM   #4
Robertcooper88's Avatar
Trader Rating: 15 (100%+)
I really like the Thunder Power motors! I have had a few issues with the RevTech, I will not use it for boosted anymore. I believe it was built for non-boosted class anyway with all that timing you can put into it. The D3 is a great motor too!!
DischargeRC.com - Race-Opts MTS T2 - TRINITY FOR POWER
Robertcooper88 is offline   Reply With Quote
Old 10-31-2011, 05:12 PM   #5
R3VoLuTiOn's Avatar
Trader Rating: 27 (100%+)
ballistic with optional vented can
trinity duo3
orca rx2
are all motors I've run and liked
John Tsang 🏁 VBC Racing 🚗 ORCA RC 🚗 GripworksRC 🚗 MotivRC 🚗 GravityRC 🚗 RC America
http://www.facebook.com/VancouverRRR 🏁 http://www.facebook.com/OvergearedRacing
R3VoLuTiOn is offline   Reply With Quote
Old 10-31-2011, 06:05 PM   #6
Buckaroo's Avatar
Just be aware that the Rev has some issues with motor can screws, and there's an alarming trend developing of them melting down when used with boost in the traditional manner.
I'd stick with a D3 or an X-12, both are proven winners that are very robust, easy to understand, and respond very well to boost.
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 10-31-2011, 07:03 PM   #7
The D3 has been a good motor and as far as the X-12 I'v had no luck with it.
My old Novak SS has been good and strong.
Friulimotosport is offline   Reply With Quote
Old 10-31-2011, 09:48 PM   #8
Trader Rating: 42 (98%+)
Send a message via Yahoo to dirt_oval
I also think the TP motors are great. Very fast for both off road and on.
Whatever motor you choose, I would keep it at 'factory' timing. Especially running boost or turbo.. or both. It will help keep everything simple until you really understand what each degree of timing is doing to the overall feel of the throttle.
And as a side note, the motor is not nearly as important in a boosted class then it is a "stock" based class. So trying to get the latest and greatest motor should not always be at the top of the agenda!
Damon English
Team Tree Top--Associated--LRP--Trinity/Revtech--Spektrum
Help the environment, and support your local hobby shop!
http://mikeshobbyshop.com
freshRC.blogspot.com
dirt_oval is offline   Reply With Quote
Old 10-31-2011, 10:11 PM   #9
caaraa is offline   Reply With Quote
Old 10-31-2011, 10:21 PM   #10
Really? I have ran the X12 with no issues. Can you explain your luck with it so I know what to possibly look for?
Damon English
Old 10-31-2011, 11:59 PM   #11
I think the Reedy Sonic is the motor of choice since its quick out of the box. It comes standard with a 12.5 mm rotor which will generate more torque which i think is most important with stock racing. My Rev tech is quick and high revving but lacks the torque. Most guys at my track that run Thunder Power used optional rotors to optimize speed.
Minh Nguyen
[Maclan Racing] [Xpert Servos]
trigger is offline   Reply With Quote
Old 11-01-2011, 04:49 AM   #12
It doesn't matter what setttings I run it just not up to the pace of the other motors and tends to come off always hot--maybe I just have got a bad one?
Old 11-01-2011, 09:01 AM   #13
Buckaroo's Avatar
The issue may be the standard of "hot". HOT for most standard motors is 160. HOT for an X12 is 210. The X12 can withstand running above 200 without letting the magic smoke out, which is certainly NOT the case with other motors at their 'roll over and die' temperature.
Specifically in 1S racing WGT/12th, the X12 doesn't seem to fall off as much as a Duo1/2/3 when it gets hot, either. Get one of those above 140ish and it's going to feel like old nicads dumping!
It's all in what you want. The D3 is an RPM motor, the X12 is a torque motor. Both can be just as fast. But most people understand RPM more than they do torque.
If you're running a Tekin, I'd get a D3. If you're running an LRP, I'd get an X12.
Tom Keith
Old 11-01-2011, 04:24 PM   #14
I'm set up running Tekin with the X-12 and had the roll out up to 101 mm, as with my D3 around 78 mm with fastlap at the track.
I do have a LRP and will give it a try. What would you recommend on the insert as now I been running it with the 4 dots installed.
Thanks for the info.
Old 11-06-2011, 06:37 PM   #15
wollow86's Avatar
So rather then post another what motor thread, I'll resurrect this one.
So, I run boosted 17.5, looking for a new motor. Short list is duo 3, sp v3 mmm, and reedy sonic. I don't like the idea of timing inserts, so I'm concerned about the sp, and I can't seem to find the duo 3 in stock anywhere (my ideal choice). The reedy looks good too, but I dont know much about it.
My main concern is the timing on the sp, currently I have my tekin redline set at 0deg motor timing. How would that translate to the sp or other motors?
Supporting Aussie hobby shops:
- www.MRJRacing.com.au - - www.feralbatteries.com.au - - www.actionrc.com.au -
wollow86 is offline   Reply With Quote
Witch 17.5 motor to buy.... Big Midget Electric On-Road 44 03-06-2011 05:47 PM
What 17.5 brushless motor +speed control sszzxx Rookie Zone 13 12-02-2008 07:08 PM
What 17.5 brushless motor +speed control sszzxx Electric On-Road 12 11-27-2008 11:14 AM
best 17.5 motor fasteddie2 Electric Off-Road 11 09-20-2008 12:04 PM
