Old 10-29-2011, 11:50 AM   #1
ep10's Avatar
Default Spektrum module question
Hello I have a question.
I have a SM1001 Pro module on my EX1-UR. However, I cannot bind withthe spektrum micro rx (I believe it's SR3500).
I read some posts saying that the micro rx is DSM2 while the SM1001 is DSM, therefore they cannot bind.
However, I saw someone using EX10 with spektrum module but using mirco rx as well. Where did I go wrong?
Are there different types of SM1001 or micro rx???
Thank you for your help!
ep10 is offline   Reply With Quote
Old 10-29-2011, 04:25 PM   #2
The SR3500 is a DSM and should bind. Are you using a bind plug?
AreCee is offline   Reply With Quote
Old 10-29-2011, 05:15 PM   #3
Try making sure everything is centered out on your radio trim adjustments before binding.
John Warner is offline   Reply With Quote
Old 10-29-2011, 06:45 PM   #4
WC
WC's Avatar
Trader Rating: 28 (100%+)
There's 2 micro surface RXs, SR3500 (DSM) and SR3520 (DSM2).
If frame rate is adjustable on UR try a slower setting.
I only have std nonPro modules in my Mars & MarsR,
they talk fine to all my DSM RXs.
www.PandaGFX.com
www.MelbRC.org
WC is offline   Reply With Quote
Old 10-31-2011, 08:59 AM   #5
TRXRACER99's Avatar
Trader Rating: 10 (92%+)
Also you might want to buy a glitch buster from novak the micro reciverse and KO radios dont like each other to much. A glitch buster will resolve the problem you will have latter in your recivers life.
TRXRACER99 is offline   Reply With Quote
Old 10-31-2011, 01:14 PM   #6
ep10's Avatar
I hope I don't confused mine with 3530.
My SR3500 looks like this, so it should be SR3500, right?
http://www.spektrumrc.com/Products/D...ProdID=SPM1210
Old 10-31-2011, 01:15 PM   #7
ep10's Avatar
Yes, and it has an orange light flashing (instead of green as on SR3001)... is this correct?
Old 11-01-2011, 01:47 PM   #8
ep10's Avatar
Thanks bro. I changed it back from UR to normal, then it can bind.
Thank you everyone's help! This forum is great!
Old 11-04-2011, 08:55 AM   #9
WC
WC's Avatar
more curiously, why aren't you using KO's own 2.4?
haha i'll get around to picking up a UR set one day as am big KO fan,
got every EX1 since 1981 AM till about half-a-doz of the Mars/R in FM
... they do run noticeably more energy-efficient on Spektrum modules
now got so many Spektrum RX it'll be hard to uproot,
so any UR will just be for the show shelf
www.PandaGFX.com
www.MelbRC.org
