Old 01-26-2012, 03:57 PM   #46
Christian great service and super fast delivery but my diff cover won't fit in my X1 diff. I was bummed because the left hub worked so well.
Independent Racer, J-Spec sand and sealer, Dog hair free since 2011
Dragarcher is offline   Reply With Quote
Old 03-01-2012, 02:49 PM   #47
CristianTabush's Avatar
Sorry, I had not seen this in forever.
I am not sure I understand, since I am not very familiar with F1's... yet...
Is it the titanium diff cap that is not working? I can forward this info to QTEQ and I can give you a better solution for it.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 03-02-2012, 12:32 AM   #48
Yes it was the diff cap on the inside of the Tamiya diff hub there is a step about half way in that stops the cap from seating.
Old 03-02-2012, 07:00 AM   #49
Is the X1 diff different?
Old 04-05-2012, 12:17 AM   #50
QTEQ Power Terminals are back in stock!
Old 04-30-2012, 10:22 AM   #51
Default NEW F Type Power Terminals!!!
We now have the F type Power Terminals in stock, which have been designed to work better with flat- type solder tabs on motors.
Old 08-25-2012, 05:55 PM   #52
Default NEW S-Type, LRP Type and ESC Power Terminals
Speedo Plugs QT-111001-5SV
LRP Style Plugs QT-111001-LRPV
S Type Plugs (short type) QT-111001-SV
Along with the plugs above, we have received the S, V, LRP sides and all the ancillary parts.
Old 08-26-2012, 06:11 AM   #53
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Very COOL!! - but you need to solder and screw them in??
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 08-26-2012, 06:54 AM   #54
Maybe this can help?
Instruction Guide for the QTEQ 64 Titanium Diff Cap For the Tamiya F104
High Strength
Long-Life
Light Weight
Optimal Rotational Balance
The QTEQ 64 Titanium Diff Cap For the Tamiya F104 is exclusive to the Tamiya F104.
Apply a very small amount of grease to the rim of an O-ring.
Install the QTEQ 64 Titanium Diff Cap For the Tamiya F104 to the original diff housing in the same way as the Tamiya original diff cap. Then insert a QTEQ stainless pin to the unit and installation is completed.
The QTEQ 64 Titanium Diff Cap does not use the M3 set screw which is used on the Tamiya original diff cap.
When the QTEQ stainless pin is inserted, there may be some O-ring chipping, but performance ofthe diff cap will not be affected.
Important:
Please make sure that a wheel is mounted when the drive unit is in operation, ---if not mounted the stainless pin may pop out.
Multiverse Inc.
http://www.multiverse.jp/
http://www.multiverse.jp/QTEQ/english/top.html
http://www.multiverse.jp/QTEQ/englis.../tf104tdc.html
T.O.P Photon EX-RCDevil PC10H3X-Xray X1
rokosam is offline   Reply With Quote
Old 08-26-2012, 09:52 AM   #55
nice looking product power bananas!!
vtecboost is offline   Reply With Quote
Old 08-26-2012, 10:41 AM   #56
K-bo they do need to be soldered, but once you have done this, it is all smooth sailing, all it takes is a 1.5 driver to tighten and loosen the screws. I have them on all my cars and motors. When I am trackside, it is so easy to swap motors, I mever really bring my iron anymore.
Old 09-25-2012, 01:26 PM   #57
What's the difference between the Speedo ones and the short ones? Is it just how many come in the pack?
-Mike
Old 09-25-2012, 01:47 PM   #58
Yes, that's the only difference. Either a pack of 5 or a pack of 3.
Old 09-26-2012, 05:44 AM   #59
k_bojar's Avatar
thanks, Christian...
i guess the speedo plugs would work on any speedo? even a GTB2?
