Old 10-28-2011, 01:08 AM   #1
Default Sluggish start
Hey guys, Just bought a new speed passion cirtix with a 13.5 speed passion motor. The motor is sensored while the cirtix is not.
I installed it into my new s411 and on trying to get started it baulks and it like the gears are stuck then when I punch it, it takes off and runs fine until it slows down and I have to accelerate again. I've tried resetting the esc, and various other settings on the esc with no luck.
I'm running 72 spur with a 38 pinion. I went down to 21 pinion and its still "chunking".
Any ideas? The drive train is silk smooth and when there is no load on the motor it spools up fine.
I've got a brand new LRP NIMH pack 5000ah that i'm using to power it and it was fine with my brushed setup.
Got me stumped...
Deepsouth is offline   Reply With Quote
Old 10-28-2011, 01:18 AM   #2
sosidge's Avatar
Notchy starting (cogging) is typical of sensorless systems... BUT the Cirtix is a sensored system and should have a sensor lead running to the motor.
Old 10-28-2011, 01:44 AM   #3
The motor has a lead but I cant find anywhere on the esc to plug it in. Looked everywhere for it and nada...
Old 10-28-2011, 02:32 AM   #4
defcone's Avatar
Trader Rating: 15 (100%+)
Underneath where u solder all the cables.
defcone is offline   Reply With Quote
Old 10-28-2011, 02:51 AM   #5
nope its all smooth
Old 10-28-2011, 03:18 AM   #6
did you get a box with no cuts and plug is under?
Maybe you might need to open it and see inside
http://www.speedpassion.net/us/produ...?p=12280&c=ESC
look at the gallery pics
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 10-28-2011, 06:14 PM   #7
Had a look at the packaging it's a cirtix inspire v2.0 sensorless esc probably why there is no place for a plug.
Does it matter that its sensorless?
Old 10-28-2011, 07:28 PM   #8
ShaunMac's Avatar
You need to ask yourself that question. If the characteristics you descibed in your first post don't bother you, then it doesn't matter. But if you want a smooth predictable start then it does matter.
ShaunMac is offline   Reply With Quote
Old 10-28-2011, 07:56 PM   #9
wingracer's Avatar
Trader Rating: 24 (100%+)
Speedpassion's description of the inspire is very confusing. From their site, I was certain it was sensored but after asking on their thread here just to be sure, found out it was not.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 10-29-2011, 03:57 AM   #10
It might be better to use a proper sensorless motor with these, I am unfamiliar with sensorless but it would makes sense
Need help, first RC, can't start it Khar00f Nitro Off-Road 30 03-05-2010 09:29 PM
STS .28 pull-start engine dino.tw Onroad Nitro Engine Zone 632 08-31-2009 07:10 AM
3.3 engine feels real sluggish revoonroids Rookie Zone 7 09-24-2008 06:22 PM
