p2k2pro....from tower >
Old 11-29-2004, 10:39 PM
pink pac man's Avatar
Default p2k2pro....from tower
a mate of mine got a trinity p2k2pro from tower...........and it says it has 30,600 rpm
and my mates has 17,982rpm
and tower says it has 67.7 efficiency and my mates has 56.6 efficiency
and tower says it has 127 power.....my mates has 60
and tower says it has 172 and my mates has 101
wtf is goin on........any1 know why its so crap
link http://www2.towerhobbies.com/cgi-bin...&I=LXAVJ2&P=ML
thanks in advance
pink pac man is offline
Old 11-29-2004, 11:35 PM
Super Moderator
Grizzbob's Avatar
Sounds like one of them was tested on the Robitronics dyno(the one with higher numbers), & the other was likely tested on Fantom's dyno. Trinity made the switch a couple of years ago(though there could still be some of the older motors out there, especially from places like Tower) to the Fantom dyno, & they just test a slightly different way(including the default voltage they test at, the Fantom I think does it at 6 volts, while the Robi's default voltage setting is 7.5, & more volts=more motor power, rpm, etc.). Makes it pretty hard to directly compare, but from my experience, both sound like they're ok, & both should run similarly well, so don't sweat it....
Grizzbob is offline
Old 11-29-2004, 11:42 PM
ottoman's Avatar
And before they used Robi they used Turbo 45's... none of those Dyno's will spit out the same numbers.
ottoman is offline
Old 11-30-2004, 03:50 AM
In defense of Tower Hobbies they state that those numbers are optimal figures. Numbers will vary between batches. We all know that every production motor isn't the same as the others.
2BAD4ALL is offline
Old 11-30-2004, 12:09 PM
edseb's Avatar
Tower just sells them. Unless its their brand, than its up to Trinity. And, like some other posts mention, it could be tested a different way; like a different dyno.
edseb is offline
Old 11-30-2004, 05:22 PM
Super Moderator
Grizzbob's Avatar
Yes, believe me, I have no doubt that the numbers Tower is quoting is from when Trinity used the Robitronics dyno(I know because I have the Robi dyno myself), & Tower just never bothered to change the numbers in their listing of that motor to reflect Trinity's change.
Grizzbob is offline
Old 11-30-2004, 05:27 PM
tower may have said that they will be lower......but they cant be as low as my mate had
Old 11-30-2004, 07:06 PM
Speedo's Avatar
Because those numbers were from a Fantom dyno. Tower's numbers are from a Robitronics, so it is useless to compare the numbers.
Speedo is offline
Old 11-30-2004, 10:34 PM
Super Moderator
Grizzbob's Avatar
Right, if you took those 2 motors right now & tested them on the exact same dyno, you'd most likely get almost identical numbers(assuming both are in the same condition). It's not the motors, it's the dyno they're tested on....
Grizzbob is offline
