Old 11-29-2004, 11:39 PM   #1
pink pac man's Avatar
Default p2k2pro....from tower
a mate of mine got a trinity p2k2pro from tower...........and it says it has 30,600 rpm
and my mates has 17,982rpm
and tower says it has 67.7 efficiency and my mates has 56.6 efficiency
and tower says it has 127 power.....my mates has 60
and tower says it has 172 and my mates has 101
wtf is goin on........any1 know why its so crap
link http://www2.towerhobbies.com/cgi-bin...&I=LXAVJ2&P=ML
thanks in advance
pink pac man is offline   Reply With Quote
Old 11-30-2004, 12:35 AM   #2
Super Moderator
Grizzbob's Avatar
Sounds like one of them was tested on the Robitronics dyno(the one with higher numbers), & the other was likely tested on Fantom's dyno. Trinity made the switch a couple of years ago(though there could still be some of the older motors out there, especially from places like Tower) to the Fantom dyno, & they just test a slightly different way(including the default voltage they test at, the Fantom I think does it at 6 volts, while the Robi's default voltage setting is 7.5, & more volts=more motor power, rpm, etc.). Makes it pretty hard to directly compare, but from my experience, both sound like they're ok, & both should run similarly well, so don't sweat it....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 11-30-2004, 12:42 AM   #3
ottoman's Avatar
R/C Tech Charter Subscriber
And before they used Robi they used Turbo 45's... none of those Dyno's will spit out the same numbers.
ottoman is offline   Reply With Quote
Old 11-30-2004, 04:50 AM   #4
In defense of Tower Hobbies they state that those numbers are optimal figures. Numbers will vary between batches. We all know that every production motor isn't the same as the others.
2BAD4ALL is offline   Reply With Quote
Old 11-30-2004, 01:09 PM   #5
edseb's Avatar
Tower just sells them. Unless its their brand, than its up to Trinity. And, like some other posts mention, it could be tested a different way; like a different dyno.
RC Car Action Editor and Photographer
Carl Hyndman
edseb is offline   Reply With Quote
Old 11-30-2004, 06:22 PM   #6
Super Moderator
Grizzbob's Avatar
Yes, believe me, I have no doubt that the numbers Tower is quoting is from when Trinity used the Robitronics dyno(I know because I have the Robi dyno myself), & Tower just never bothered to change the numbers in their listing of that motor to reflect Trinity's change.
Bob Seay
Go Pokes!!!
Old 11-30-2004, 06:27 PM   #7
tower may have said that they will be lower......but they cant be as low as my mate had
Old 11-30-2004, 08:06 PM   #8
Moderator
Speedo's Avatar
Because those numbers were from a Fantom dyno. Tower's numbers are from a Robitronics, so it is useless to compare the numbers.
Speedo is offline   Reply With Quote
Old 11-30-2004, 11:34 PM   #9
Super Moderator
Grizzbob's Avatar
Right, if you took those 2 motors right now & tested them on the exact same dyno, you'd most likely get almost identical numbers(assuming both are in the same condition). It's not the motors, it's the dyno they're tested on....
Bob Seay
Go Pokes!!!
Tower Hobbies. TOWER™ Terror 25 Nitro 4WD fstnv1 R/C Items: For Sale/Trade 4 01-19-2008 10:02 AM
tower $30 off $200 bigemike Electric On-Road 6 09-18-2007 06:20 PM
Trinity P2k2Pro ARM- pls help! sonneteer Electric On-Road 21 07-14-2006 05:46 AM
p2k2pro hippykakka Electric On-Road 9 01-05-2005 02:25 PM
Tower fatdoggy Chat Lounge 39 09-17-2001 11:52 AM
