Old 05-15-2012, 06:49 PM   #31
Jonnydb's Avatar
Send a message via MSN to Jonnydb Send a message via Skype™ to Jonnydb
Originally Posted by COLD AS ICE View Post
Well i got to put my new esc to a true test this saturday, and in the heat of the day it remained "cold as ice" which satisfies me a ton! Its also very smooth, the power delivery is so linear when paired with the plutonium motors, didnt have a chance to try another motor, not sure i want to though
which motor did you use?
how about the lap times?
T.O.P Racing Brazil
Jonnydb is offline   Reply With Quote
Old 05-15-2012, 06:57 PM   #32
Trader Rating: 19 (100%+)
I was running 17.5t plutonium edition motor. Attached is the official A-Final sheet
the really low lap times it shows were computer glitches, the track was 140x60 and a fairly flowing layout but with a 180 at the end of the straight with a chicane on the front under the driver stand.
★Randy Banks★
COLD AS ICE is offline   Reply With Quote
Old 05-15-2012, 09:16 PM   #33
Jonnydb's Avatar
Cool
is good to know has good power untill finish the hit.
and how about the changes on esc? you can feel the changes?
i believe untill the end of month i will arrive my esc and motors
T.O.P Racing Brazil
Old 05-16-2012, 09:50 AM   #34
Cool
I was running in the 17.5 non-ramping class so i didnt play with any of the boost settings at all. However, i did mess with other setting in the ESC and they are very noticable, but its a good feel. Once i found the settings i personally liked, i left them alone. When i soon run modified then I will play with boost settings, but right now the biggest, most competetitive class is the 17.5 NR class.
★Randy Banks★
Old 06-04-2012, 01:11 PM   #35
Jonnydb's Avatar
last weekend i received my stuff from TP and i made a little review.
im still working on esc settings, i was accostomed with GM
the review is in postuguese but can use the google translate, wont be a 100% but is very helpful
http://www.rceletrico.com.br/forum/v...p?f=13&t=33014
T.O.P Racing Brazil
Old 06-04-2012, 01:46 PM   #36
*SBH*'s Avatar
Hi Johnny
What kind of capacitors did You change to?
Soeren
*SBH* is offline   Reply With Quote
Old 06-04-2012, 03:12 PM   #37
Jonnydb's Avatar
Originally Posted by *SBH* View Post
Hi Johnny
Soeren
Hi Soeren,
i had one of GM Capacitors for backup and used this one, is the GM 97168.K
is 5 capacitors of 420 if i remmember right.
T.O.P Racing Brazil
Old 06-04-2012, 03:13 PM   #38
Jonnydb's Avatar
the track:
T.O.P Racing Brazil
Old 06-04-2012, 03:31 PM   #39
the track:
That track is HUGE! this coming weekend i will be running modified with my Team Powers ESC and motor this weekend for the first time, and battery if my new order arrives in time. I will be using 6.5t motor with boost. track will be 165ftx40ft. Will post results and settings at the end of the race day
★Randy Banks★
Old 06-04-2012, 03:47 PM   #40
Jonnydb's Avatar
yes its a little big but usually i use the ratio between 7.5 ~ 8.4 with 10.5T
after the test share your opinion
another thing that i think that will help is a fan directly on esc, i think!
T.O.P Racing Brazil
Old 06-04-2012, 07:41 PM   #41
venom54's Avatar
Default XPS Pro new version.
Originally Posted by venom54 View Post
XPS Pro for 13.5 Boosted.
Try these settings for a 13.5 Plutonium motor on a low grip track.
1 FWD / BRAKE
2 LIPO CUT AT 6.0V
3 DEAD BANK AT 6% (DEPENDING ON YOUR RADIO)
4 HEAT PROTECTION ON
5 REV FORCE AT 0%
6 BRAKE LEVEL AT 2
7 BRAKE FORCE AT 75%
8 DRAG BRAKE AT 0%
9 FWD LEVEL AT 2
10 PUNCH AT 60%
11 POWER BAND AT 100%
12 START RPM AT 4000
13 TIMING BURST AT 65%
14 TIMING BOOST AT 50%
15 TURBO DELAY AT 0.3 SEC
16 TURBO BOOST AT 35%
FDR ON CAR WAS 7.32 FOR A SERPENT S411.
Temps for motor stayed at 60 to 68 Degree Celcius all week end.
Super smooth and plenty of go. Straight speed was equal if not a little better than others.
Hope this helps.
Cheers
Ren
Two new settings for two different tracks.
This on is for a big flowing track ::
1 FWD / BRAKE
2 LIPO CUT AT 6.0V
3 DEAD BANK AT 8% (DEPENDING ON YOUR RADIO)
5 REV FORCE AT 0%
6 BRAKE LEVEL AT 2
7 BRAKE FORCE AT 80%
8 DRAG BRAKE AT 0%
9 FWD LEVEL AT 2
10 PUNCH AT 0%
12 START RPM AT 3000
13 TIMING BURST AT 60%
15 TURBO DELAY AT 0.2 SEC
16 TURBO BOOST AT 50%
Very fast, equal or better in speed to the three front runners. Only let down was incorrect settings on car for rotation into corners. To much push!
This one tested on a very tight technical track with short straights and multiple hairpins ::
1 FWD / BRAKE
2 LIPO CUT AT 6.0V
5 REV FORCE AT 0%
6 BRAKE LEVEL AT 1
7 BRAKE FORCE AT 90%
8 DRAG BRAKE AT 0%
9 FWD LEVEL AT 1
10 PUNCH AT 0%
13 TIMING BURST AT 70%
14 TIMING BOOST AT 55%
15 TURBO DELAY AT 0SEC
16 TURBO BOOST AT 0%
Turbo not used as track was very tight and cold but still very fast and punchy out of corners.
Above is a sample photo of the Mornington track.
Car was S411 and FDR was 7.32 with Plutonium 13.5 and 6800 70C batteries.
Cheers Ren
Play hard but be nice to your parents!
VBC RACING|ASSOCIATED|XRAY|TEAM POWERS|THUNDER TIGER|HOBBYWING|HPI|WTF FANS|ORION AND MORE IN STORE.
145 COMO PARADE EAST 3195 PARKDALE VICTORIA AUSTRALIA.
www.rabhobbies.com.au
venom54 is offline   Reply With Quote
Old 06-05-2012, 06:49 AM   #42
*SBH*'s Avatar
Hi Soeren,
Thanks, I am sure I can find one of those in my box
Old 06-05-2012, 07:09 AM   #43
Craig W's Avatar
Send a message via MSN to Craig W Send a message via Skype™ to Craig W
1 of these will do the job
Orca www.ChubbiesCarShack.co.uk TDX SMC RC Airbrush Fundecal
Craig W is offline   Reply With Quote
Old 06-05-2012, 10:59 AM   #44
Jonnydb's Avatar
you will "feel" a better acceleration, for me worked
T.O.P Racing Brazil
Old 06-05-2012, 11:00 AM   #45
Jonnydb's Avatar
Sure, i used that one because its only i had at the moment
T.O.P Racing Brazil
