Old 10-26-2011, 01:28 AM   #1
Geberit's Avatar
Default Gearing Pro Stock ETS
I will be driving the combination AE TC6, Speed Passion 13,5T V3 and CIRTIX Stock (Pro stock ETS Races).
Now I would like to buy some different pinion/gear and I have no clue in which range of Gearing to look!? Something between 4 and 5.5 or so?
Thanks for any suggestions!
Geberit is offline   Reply With Quote
Old 10-26-2011, 01:40 AM   #2
that seems a little low, around 6ish for 13.5t, I run 7.50ish for 10.5t, you will have to get the 80t spur gear probably too.
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 10-26-2011, 02:08 AM   #3
ETS is without timing, so I would say FDR 4-4.5'ish
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 10-26-2011, 02:16 AM   #4
Pro10noob's Avatar
Yup go for the 4.0 to 5.0.
If your running indoor on a short tech track you need the higher FDR.
On the big outdoortrack in the Netherlands they run 4.0
Not raced at a ETS event but been to some of the Dutch tracks and know what they drive there with the Cirtix SP V3 combo.
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 10-26-2011, 02:17 AM   #5
Ronald B's Avatar
Indoor ets 4,5 for pro stock
Ronald B is offline   Reply With Quote
Old 10-26-2011, 02:19 AM   #6
Tbone13's Avatar
Hy,
like Ronald told ..max gearing is 4,5 allowed !!
last year I used 4,7 cause it was better over 5 minutes
kind regards
Tom
supported by and thanks to:
Modelconcept / Absima Racing / TeamC / Hacker Brushless motors / Awesomatix
Tbone13 is offline   Reply With Quote
Old 10-26-2011, 03:00 AM   #7
Just choose here - Gears TC6 , like they have said pay attention to max gearing allowed, but i would say for 48dp, 72/32 looks perfect. Hope this helps.
Team AME/ORCA
https://www.facebook.com/strawberryrcdesigns
http://www.strawberryrcdesigns.pt/
jorgesimes is offline   Reply With Quote
Old 10-26-2011, 03:18 AM   #8
Geberit's Avatar
Thanks for all your input! This helps a lot!
Paposwing's F1 nation discussions PAPOSWING Racing Forum 727 08-09-2011 06:24 PM
2009/2010 WCICS thread stulec52 Canadian R/C Scene 1095 03-31-2010 10:29 AM
