Xray X12 1/12th pan car 2011 >
Old 10-22-2011, 12:23 AM
Default Xray X12 1/12th pan car 2011
Xray have released the next evolution of the XII, the all-new Xray 1/12 pan car platform, the X12. They have created a car that works exceptionally well for beginners, highly-skilled drivers and everyone in between.And to make a car even easier to work on, they replaced the side shock with newly-designed side tube lateral dampers. Lowered rear bulkheads and an improved rear axle system allow the use of super-small tires while providing a super-low center of gravity.
All-new X12 specs:
Chassis:
- New battery position placement (horizontal) for better car balance and weight transfer
- New harder chassis material to make the car easier and more stable for high bite tracks
- Longer chassis for greater wheelbase for better stability
- Holes for suspension mounting are wider which create wider width to make car easier to drive
- Platform designed and optimized for LiPO batteries and brushless motors
Rear bulkheads:
- Lowered rear bulkheads to allow the rear axle to move lower which allows to use smaller tire diameter and allows to move lower the weight
Rear axle:
- New system of steel part mounting into the graphite tube makes the rear axle more durable
Front suspension:
- Lower, upper arms and steering blocks made from harder material to make the car easier to drive and more forgiving mainly on high bite tracks
- Plastic balls for king pin are used for smoother steering
Side tubes
- Side tubes replace side shock for smoother and more consistent operation
Side springs:
- Placed directly to chassis for smoother and better movements
Center Shock:
- The shock shaft is extended which makes the center shock longer for better dampening
Servo saver:
- New 4 spring servo saver makes the car more consistent and easier to drive. Makes the car steer more precise
Servo positions:
- Two servo positions for allowing to perfectly balance the weight transfer
flyfish is offline
Old 10-22-2011, 12:24 AM
I think it's cool
flyfish is offline
